SteveNMaine |
Member ![]() ![]() Group: Members Posts: 50 Joined: 12-August 24 From: Maine Member No.: 28,288 Region Association: None ![]() |
I just setup my carbureted 2056 with 123Ignition distributor and cannot get it started.
Basics: Compression is good, new dual carbs and there is spark. I have read several methods of setting static timing, Method 1: 123 manual says set timing marks at 0 TDC and turn distributor till light turns green, I did that, no Joy. Method 2: Set timing marks at 7.5 BTDC and turn distributor till light turns green, I did that, it sounded more like it wanted to start but no joy. Should I continue to advance the timing? |
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,807 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
Call Ed at 1-2-3
(440) 668-8164 He’s the guru |
wbgoggans |
Member ![]() ![]() Group: Members Posts: 62 Joined: 22-April 20 From: Athens,GA Member No.: 24,167 Region Association: South East States ![]() |
Call Ed at 1-2-3 (440) 668-8164 He’s the guru I recently installed my ignition 123 using method number 1. I have not taken my motor off the stand yet so can't confirm whether or not that is correct. I am told it's import to rotate the dizzy the opposite direction of how the rotor will rotate while running when you are looking for the greenlight. our motors rotate clockwise so you would rotate your dizzy counter clockwise until you see the greenlight. Please keep us updated if you find a solution. would be cool to start an ignition 123 troubleshooting thread. |
FlacaProductions |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,964 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California ![]() ![]() |
Yup. Install and rotate counter-clockwise juuuuust until the green light comes on.
Lots of us have worked thru this - keep us posted with details. You'll get it. It's worth it. |
Robarabian |
914 A Roo ![]() ![]() ![]() Group: Members Posts: 695 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California ![]() ![]() |
What Flaca said... you don't just turn it... align the rotor to the #1 plug wire while at TDC. Then power it up. turn COUNTER CLOCKWISE until the light turns green. Back it off till it turns off and then back to "just turning green." you want to be just at that edge of it turns on. You then push the rotor (not the whole dizzy) slightly clockwise (the direction the rotor turns) and make sure it stays green while you snug down the dizzy. You are static.
dtmehall |
Member ![]() ![]() Group: Members Posts: 128 Joined: 21-December 23 From: Farmington Hills, Michigan Member No.: 27,808 Region Association: Upper MidWest ![]() |
not to be a dinosaur, but this is a very similar procedure to the one described in 'How to keep your Volkswagen Alive' book by John Muir.
SteveNMaine |
I have the 123/TUNE+4-R-V-POR What should I be programming in for advance? Maybe that is the issue?
FlacaProductions |
Here's a note I have saved from Ian concerning setup that might help you: http://www.914world.com/bbs2/index.php?s=&...t&p=3110141
Jake Raby taught me a simple method. First, follow the directions for installation, which will get you to a point where the car runs. Set a curve point for 8 degrees @ 1K RPM, a point for 27 degrees @ 3000 rpm and a point for 27 degrees at 5K. Load that curve into the 123 distributor. Then hook up a timing light, cap off the vac advance and rev the engine to 3K RPM. I like to aim at the notch on the flywheel. Rotate the 123 until you’re showing 27 degrees BTDC @3K and then lock the unit down. The app and dizzy are now synched and you’ve approximated a simple stock curve. Now the fun begins. Drive around and see if there are any flat spots in acceleration. Make note of the rpm’s where the power seems to dip. Add points there to fine tune the advance. You’ll probably need a little more advance a little earlier. You may also need to tweak your idle advance a bit until it runs smoothly. Of course the condition of your engine, altitude and a bunch of other factors come into play. |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,199 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
I still have not been able to get my 2056 to start with the 123Ignition. It sounds like it wants to start but no joy. I followed the installation instructions and even talked to the factory, no joy. I have tried almost every curve I can find on the forums, no joy. I am sure it is a timing thing but just cannot figure it out. I am just about ready to give up and sell off the project, two 1974 1.8 bodies, three engines (1.7, 1.8 and the 2056), two side shifter transaxles, etc. I see no path forward; it has just become too frustrating. This will be the first project I ever walked away from. Will be easier to help you if all info is kept in one thread Don’t give up. In order to help you’re going to have to do some work to better describe what has been done, what the symptoms are right now, and you’ll likely need to do some hands on troubleshooting. You mention new carbs. You don’t mention if the engine has ever successfully run on those carbs with the old distributor. First off without even knowing your symptoms, I’m going to state that it is possible that in the process of removing your old distributor, that the distributor (dizzy for short) drive gear can be partially lifted out as the dizzy is removed and then the dizzy drive gear can drop back into place one or more teeth off. This can happen without you even knowing it has happened. To get to the bottom of this will require some significant effort on your part. The best approach will be to start from scratch and reverify timing all the way back to Cylinder #1 top dead center of the compression stroke. If you’re game, you’ll find the help you need. |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,823 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
If it ran well before you pulled the distributor, then the distributor drive is probably indexed properly. I’ve never had the drive gear come out with the distributor.
When in doubt take off the valve cover to make sure you’re on TDC #1, you could be 180* out, remember it takes two revolutions of the crankshaft to complete the firing order. Next make sure the distributor drive is properly installed per the workshop manual. Then make sure the rotor and cap are on #1. 123 distributors are installed at zero degrees on TDC #1. The distributor handles all the advance. |
SteveNMaine |
Here's a note I have saved from Ian concerning setup that might help you: http://www.914world.com/bbs2/index.php?s=&...t&p=3110141 Jake Raby taught me a simple method. First, follow the directions for installation, which will get you to a point where the car runs. Set a curve point for 8 degrees @ 1K RPM, a point for 27 degrees @ 3000 rpm and a point for 27 degrees at 5K. Load that curve into the 123 distributor. Then hook up a timing light, cap off the vac advance and rev the engine to 3K RPM. I like to aim at the notch on the flywheel. Rotate the 123 until you’re showing 27 degrees BTDC @3K and then lock the unit down. The app and dizzy are now synched and you’ve approximated a simple stock curve. Now the fun begins. Drive around and see if there are any flat spots in acceleration. Make note of the rpm’s where the power seems to dip. Add points there to fine tune the advance. You’ll probably need a little more advance a little earlier. You may also need to tweak your idle advance a bit until it runs smoothly. Of course the condition of your engine, altitude and a bunch of other factors come into play. Unfortunately, I went through the setup procedure even with the help of the factory folks over the phone and still cannot get the engine to start. I am going to go back to the Bosch distributor and if that doesn't work I am going to scrap the whole project. |
Make sure there’s a center contact in the distributor cap. I’ve seen that problem a couple times.
SteveNMaine |
Here's a note I have saved from Ian concerning setup that might help you: http://www.914world.com/bbs2/index.php?s=&...t&p=3110141 Jake Raby taught me a simple method. First, follow the directions for installation, which will get you to a point where the car runs. Set a curve point for 8 degrees @ 1K RPM, a point for 27 degrees @ 3000 rpm and a point for 27 degrees at 5K. Load that curve into the 123 distributor. Then hook up a timing light, cap off the vac advance and rev the engine to 3K RPM. I like to aim at the notch on the flywheel. Rotate the 123 until you’re showing 27 degrees BTDC @3K and then lock the unit down. The app and dizzy are now synched and you’ve approximated a simple stock curve. Now the fun begins. Drive around and see if there are any flat spots in acceleration. Make note of the rpm’s where the power seems to dip. Add points there to fine tune the advance. You’ll probably need a little more advance a little earlier. You may also need to tweak your idle advance a bit until it runs smoothly. Of course the condition of your engine, altitude and a bunch of other factors come into play. Unfortunately, I went through the setup procedure even with the help of the factory folks over the phone and still cannot get the engine to start. I am going to go back to the Bosch distributor and if that doesn't work I am going to scrap the whole project. It is getting spark, I just can't get the timing right. |
emerygt350 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,982 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States ![]() |
Have you tried starting fluid?
Timing is just timing. You can be way, way, way off and the engine will do something. Normally a frightening something, but something. |
Stratfink |
Member ![]() ![]() Group: Members Posts: 76 Joined: 27-December 21 From: SoCal Member No.: 26,198 Region Association: Southern California ![]() ![]() |
Hang in there Steve. Several of us struggled to get the initial set up correct and to get the car started with the 123 - but it’s worth it once up and running.
Sounds like you have spark - but one thing to check is making sure the connections to the ignition coil are not reversed (ask me how I know). I also found that setting a flat curve at 10 degrees in the app and then using my timing light at 10 degrees was an easy way to sync the dizzy and did not require holding any specific rpm while setting timing. Once sync’d the curves from others can be programmed in as your start point. There are threads with this technique out there and I’m happy to search for them if needed. |
Lo-Fi Version | Time is now: 4th July 2025 - 05:53 AM |
