> Brain Trust Help needed on Parking Brake Light, Parking Brake Light Always on......
Gatornapper
post Jul 4 2025, 07:40 PM
Once again need the help of the great 914 Brain Trust here........
My Parking Brake Light stays on all the time.
The switch is fairly new and it is functioning properly.
Disconnecting the brown (ground) wire to the switch, it has no continuity or resistance to ground. So it is not "grounded out" somewhere.
I see in my great 914 electrical schematic of the ground circuit for the switch and light that there are two diodes in the circuit.
I am guessing that one of them failed.
Can anyone tell me where these two diodes are located?
Or where else the problem might be?
As always,
TIA,
GN
jim_hoyland
post Jul 4 2025, 08:41 PM
Get that VIN ?
MC ?
I just went through this… (IMG:style_emoticons/default/smile.gif)
Jamie
post Jul 5 2025, 09:03 AM
QUOTE(jim_hoyland @ Jul 4 2025, 06:41 PM) *
MC ?
I'm also trying to troubleshoot the flashing red instrument light. Didn't locate the brake switch illustrated in the shop manuals, and have no good access down beside the seat. Have pushed the MC pin in several times with no effect, no leaks, and brakes are working just fine. Don't know what to try next? (IMG:style_emoticons/default/blink.gif)
Literati914
post Jul 5 2025, 10:01 AM
@Gatornapper - if you pull the combo gauge, you'll see the two diodes... (your model may be different, but) on my '72 there are two diodes going to the e-brake/MC flashing bulb - one diode is looped over from the generator bulb and the other diode is where two Brown/White wires are combined (these are e-brake and 'fasten seat belt dash light').
But before looking in to those - pull the other single Brown/White wire from the bulb and see if the flashing stops.. that's the wire from the MC, and you can isolate the problem that way.
Gatornapper
post Jul 5 2025, 10:47 AM
Ah yes! On my schematic it does look like one diode is next to bulb. Other one seems to be near the switch but I don't see one there......
Great suggestion, I will do this.
THANK YOU!
Will let you know.
What is "MC"?
GN
QUOTE(Literati914 @ Jul 5 2025, 10:01 AM) *
@Gatornapper - if you pull the combo gauge, you'll see the two diodes... (your model may be different, but) on my '72 there are two diodes going to the e-brake/MC flashing bulb - one is looped over from the generator bulb and the other is where two Brown/White wires are combined (these are e-brake and 'fasten seat belt dash light').
BillC
post Jul 5 2025, 11:05 AM
QUOTE(Gatornapper @ Jul 5 2025, 12:47 PM) *
What is "MC"?
"MC" is short for Master Cylinder.
Literati914
post Jul 5 2025, 12:10 PM
QUOTE(BillC @ Jul 5 2025, 12:05 PM) *
What is "MC"?
Yea that flashing bulb is not just the E-brake warning light - it's also the Master Cylinder warning light. So the non-stop flashing could be from either circuits going to the bulb. You can pull one at a time and see if the light stops blinking. Alternately you could pull the wires off the MC itself.
Superhawk996
post Jul 5 2025, 12:23 PM
Simplified schematic from Spoke Attached Image
Superhawk996
post Jul 5 2025, 12:25 PM
QUOTE(Jamie @ Jul 5 2025, 11:03 AM) *
Troubleshoot with Multimeter using Spokes schematic above
Gatornapper
post Jul 9 2025, 05:44 AM
Ah, yes.
Thank you SH for the schematic.
NO diodes at light in left gauge - none in sight anywhere. See none in schematic above either. My 914 is '76.
But I will check the Brake Fluid. I just bled the brakes a week ago with 15psi on fluid reservoir system. So reservoir is full.
GN
Spoke
post Jul 9 2025, 06:36 AM
Jerry
For the MC warning switch, you can disconnect the wires to see if the warning light goes out. Same with the ebrake switch. The flasher will flash with relatively little current through the switches or other leakage.
Gatornapper
post Jul 11 2025, 06:41 AM
Thanks Spoke.
Light still flashes with brake wire disconnected.
Gotta get under car to remove MC wire I guess.........yes, light flashes.....
Is wire to MC looking for fluid in MC?
Just bled my brakes and light still flashes. My 914 has 911 MC. Brakes work great, reservoir is full.
GN
QUOTE(Spoke @ Jul 9 2025, 06:36 AM) *
post Jul 11 2025, 07:23 AM
Is there a reset button/Switch on the Master Cyl?
914/Alan
Cairo94507
post Jul 11 2025, 08:06 AM
Michael
On my MC there is- ATE. (IMG:style_emoticons/default/beerchug.gif)
Jamie
post Jul 11 2025, 08:55 AM
QUOTE(914 @ Jul 11 2025, 05:23 AM) *
914/Alan
I've tried that reset switch multiple times without resulting in ending the flashing. Will next remove the wire from the MC when I can next get the car up on the lift.
Gatornapper
post Jul 14 2025, 03:14 PM
I'll do the same. Lift presently occupied preparing my sweet 944 S for buyer next week. After acquiring my Concours 951 last September, my beloved wife thinks no man needs two nice 944's, and I actually agree.
What in the world does this wire to the MC do? Make sure there is fluid in MC? Why is there a reset on it?
GN
QUOTE(Jamie @ Jul 11 2025, 08:55 AM) *
914/Alan
Superhawk996
post Jul 14 2025, 05:47 PM
QUOTE(Gatornapper @ Jul 14 2025, 05:14 PM) *
The master cylinder switch senses a loss of pressure in either of the two braking circuits.
If there is a pressure differential across the sensing piston inside the master cylinder, it trips the latching switch.
This will occur during brake bleeding - thus the reset switch.
If you haven’t bled the brakes and this circuit is being tripped, it is a serious issue and shouldn’t be ignored.
Gatornapper
post Jul 17 2025, 06:07 AM
Change of subject as I have no where else to go: This is the best forum on the planet for a car, and seems to have the best electrical guys like SuperHawk and Spoke, etc.
Any of you guys have a 944? Have strange problem on my '87 944 S re: ignition switch and 12v to AC compressor clutch.......
If so should I start new thread or handle this via PM?
GN
Literati914
post Jul 17 2025, 12:35 PM
I have the same issue with the stupid flashing light caused by the M.C., I’ve unplugged it’s wire from the bulb for the time being (e-brake still causes it to flash as it should when up).
I’d say ‘don’t be surprised if there is no reset button to push’ … I have 3 old 914 master cylinders and none of them have a reset button. Am I missing something? They all have some type of a square plastic “tower” where the spade(s) are … is that somehow the reset “button”? I lightly tried prying the plastic block off on one and that didn’t seem to be the case (IMG:style_emoticons/default/confused24.gif)
In the pic below, the separate warning switch does actually have a button (under a little cover that's meant to be temporarily removed). I switched it out for a two-spade switch before installing my 914rubber after-market MC and am now wondering if there's maybe a compatibility issue.. did so because my car has an obvious ground wire in that location for the MC. I think I’m gonna try going back to the single spade unit and see if I can get the light to stop blinking.
Gatornapper
post Jul 17 2025, 07:28 PM
Thanks.
Gonna unplug mine - if there is one. My MC is from a 911 - does that one have same reset button and wire?
I'll just monitor my brakes and brake fluid level closely. No need for warning light.
E-Brake switch is another matter - too many times I've driven off with E-brake on!
GN
QUOTE(Literati914 @ Jul 17 2025, 12:35 PM) *
- Lo-Fi Version Time is now: 4th September 2025 - 02:18 AM
