| sburns1967 |
Aug 7 2025, 06:20 PM
Newbie ![]() Group: Members Posts: 11 Joined: 16-May 25 From: London, Ontario, Canada Member No.: 28,775 Region Association: Canada |
Going to look at this 1973 914/2.0 next week.
Looking at this picture I am wondering if there is a problem with the suspension. Is the front cranked up and the rear drooping/collapsed? ![]() |
| windforfun |
Aug 7 2025, 06:36 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,098 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None
Either new springs or too much beer in the trunk. 100 lb springs will work.
| NARP74 |
Aug 7 2025, 06:48 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,448 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Front looks right, back is jacked. Generally if you follow the line at the bottom of the doors and fenders to the wheels, they will bisect the center of the wheels. I believe that is approximately stock height. Front is correct, back is too low for some reason. Needs eyes on to figure out what is going on.
Is that the Carolina squat on a pick up truck? |
| Optimusglen |
Aug 7 2025, 06:52 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 940 Joined: 26-February 16 From: Minneapolis Member No.: 19,709 Region Association: Upper MidWest
Old 914 rear coil springs can sag, new 100lb springs are good.
My opinion, keep the rear low and lower the front to match. |
| sburns1967 |
Aug 7 2025, 07:13 PM
Thank you for the quick replies. I will take a look at the rear next week.
Scott |
| bkrantz |
Aug 7 2025, 08:15 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,656 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
Check to see if the rear shocks have adjustable perches, and what height the PO set.
| Artfrombama |
Aug 7 2025, 08:47 PM
Artfrombama ![]() ![]() Group: Members Posts: 446 Joined: 21-January 24 From: One of the chosen few Member No.: 27,870 Region Association: South East States
100# springs from 914 Rubber raised the rear of my car right at an inch.
| NARP74 |
Aug 8 2025, 07:59 AM
Check the door gaps, same top and bottom. Smaller at the top is trending bad. Car could be sinking due to rusted frame structure.
| SirAndy |
Aug 8 2025, 09:17 AM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,473 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I've never seen rear springs sag that much.
There's something else going on. Check for rusted suspension consoles. (IMG:style_emoticons/default/blink.gif) |
| rjames |
Aug 8 2025, 09:52 AM
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,448 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
I've never seen rear springs sag that much. There's something else going on. Check for rusted suspension consoles. (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/agree.gif) Although I suppose it could just be that the front is jacked up so high it's putting added weight on the rears in addition to the spring perch being too low... They definitely went wild with the paint- going over the handles and the bumper tops. I'm betting there's a ton of overspray. |
| sburns1967 |
Aug 8 2025, 09:55 AM
Thanks for the note on the door gap and suspension points to look at.
If nothing obvious I am going to have it sent out to the local Porsche dealership for a PPI. Thanks again Scott |
| Root_Werks |
Aug 8 2025, 11:42 AM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,946 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
People also like to cut springs, just saying.
(IMG:style_emoticons/default/sawzall-smiley.gif) That front spoiler is so low with the rubber lip, looks like lowering the front would cause that to hit pretty much everything. (IMG:style_emoticons/default/driving.gif) |
| flxzcat |
Aug 8 2025, 02:53 PM
Member ![]() ![]() Group: Members Posts: 102 Joined: 13-June 11 From: Lake Forest, So. Cal. Member No.: 13,188 Region Association: Southern California |
I think the rear is right and the front is wrong (IMG:style_emoticons/default/lol-2.gif)
| wonkipop |
Aug 8 2025, 04:08 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,480 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
| sburns1967 |
Sep 15 2025, 02:20 PM
Ending up aborting the purchase of that one and bought a partially finished project car from a member on the Porsche 914 Canada FB group. Hope to have it here the first of October to inventory what remains.
Will be looking for an engine builder in Canada if anyone has any pointers in this area. Thanks for the info on the prior car I posted enabling me to determine it had some serious issues on my second inspection. |
| IronHillRestorations |
Sep 15 2025, 04:01 PM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,927 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
If the front of a 914 is higher than the rear it will handle really floaty at speed. The front should be slightly lower than the rear.
| scottthephotog |
Sep 16 2025, 08:04 PM
Member ![]() ![]() Group: Members Posts: 200 Joined: 20-November 18 From: Louisville, TN Member No.: 22,667 Region Association: Southwest Region |
| sixnotfour |
Sep 16 2025, 10:12 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,199 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
| 914Sixer |
Sep 17 2025, 06:19 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,466 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
914's where set up in front a little to meet headlight regulations at the time. Set your car up where you want it. A quick check is to measure from center of the front wheel to the floor, it should be 12" on stock tire.
| wonkipop |
Sep 17 2025, 06:31 AM
Either new springs or too much beer in the trunk. 100 lb springs will work. Beer goes up front.. you are closer to the truth than you think. (IMG:style_emoticons/default/biggrin.gif) all vws of that era were set up nose high (though not quite to the levels of the yellow example discusssed here). super bugs. 411/412s, type 3s,.........and 914s. vw policy. to take a loaded front trunk basically. it could be the usa headlight height story but i susoect thats a myth. all the vws stock were like that here in australia too. nose high. slightly. when unloaded. a thought. but there is definitely something not right about the yellow one. way off on the nose up attitude. |
Lo-Fi Version | Time is now: 16th April 2026 - 12:44 AM |
