> Intake Manifold Leak at #3
frank_c
post Aug 10 2025, 11:30 PM
Hello,
I've been chasing a dead #3 cylinder since I purchased a '76 2.0 earlier this year.
The engine has Webers, and my first clue that something was not right with #3 was when I set out to tune the carbs soon after the purchase, and the mixture screw had no impact on the idle - even screwed all the way in. Nor did choking off the cylinder, or even pulling the spark plug. I confirmed that the plug was firing, but cleaning the idle jet and circuit did not help. So, I pulled the carbs to rebuild them and do a closer inspection.
While disassembling the right carb, I noticed that the circlips that hold down the enrichment circuit valves had popped out, and assumed that was probably flooding the cylinder as I did not find any other issues.
I installed the rebuilt carbs, and found that #3 was still dead. I sprayed carb cleaner at the base of the intake manifold, and the idle increased - so obviously I had a vacuum leak there.
I did not replace the phenolic gaskets/spacers and assumed this was likely the source of the leak, so I ordered new ones. I know there is some debate on whether to used the spacers or not with carbs, but at least regarding the icing concern - I live in central TX, so not so much of a issue. I'm more concerned with the gas boiling out of the float bowls after shut-down (it happens with my 911).
To give me the best chance of success with the new gaskets, I used a bastard file to ensure that base of the manifold was flat (same file I used for truing the SSI exhaust manifold ports).
While installing the new gaskets, I noticed something that I thought for sure was the source of the leak. The engine tin at the #3 intake port was just slightly overlapping the intake port sealing area (see photo). It looks like someone may have filed away a bit of the head at that spot to provide a relief for the tin - but it wasn't enough. I trimmed the tin slightly to ensure there was a gap.
After re-assembly, to my surprise #3 was still mostly dead. It did react a little to carb cleaner in the throat so there was an improvement, but the mixture screw still did nothing, and I found that the vacuum leak at the intake port was still there.
I removed the phenolic gasket, made my own cork gasket, re-installed the carb+manifold - and finally #3 is working as it should with no leaks at the intake port. I was able to tune & balance/sync the carbs quickly (I also installed Chris' cable throttle linkage), and during a test run the car ran well and there was no popping either through the intake or exhaust. Prior to all this, the popping in the exhaust was so loud it sounded like gunfire.
So here's my question - given that I believe the intake manifold surface is flat (after filing), is it possible that the right head is warped which is why the phenolic (with paper) gasket won't seal, but the cork gasket does? I don't mind purchasing new intake manifolds if that is the more likely culprit. Note that we are talking about #3 here - the hot one, but when searching I did not find any references to warping at the intake ports.
Sorry for the long post, and thanks for any suggestions.
GregAmy
post Aug 11 2025, 06:33 AM
Welcome to my fight of the last two months...I fought low vacuum and a dead #3 on my Dells-equipped racer for a while before someone suggested pulling the intake...duh. Frustrating, as this was after I bought a sonic cleaner and rebuilt the carbs...again (I think I secretly wanted an excuse to buy that anyway).
I have been manually trimming away the sheet metal to ensure it does not interfere with either the phenolic or the intake manifold. It doesn't take much. It's much easier with the engine sitting on the bench, of course.
If you have put a flat scale on the intake manifold, and have ensured that there's no leftover gasket material on the head...I honestly can't imagine the head being warped. But no way to know without pulling the studs and putting a flat across it.
If there's any doubt about the flatness of the manifold, take it to a machinist and have them skim it (I don't like doing that by hand). I laid a flat steel scale across mine and could not get a .002 under it anywhere.
VaccaRabite
post Aug 11 2025, 07:15 AM
En Garde!
Back when I had carbs on my car, I spent an afternoon slowly milling down my intake runners using 400 grit paper on a sheet of glass until they were totally even. Then I went to 800 - because, well, overkill.
The castings from the factory are not flat at all.
Zach
frank_c
post Aug 11 2025, 05:37 PM
Thanks for the feedback. I knew that my hand filing would only correct any gross un-evenness (and hopefully not make it worse). I could see that there was a low spot in the center when I started filing (photo) - the green sharpie lines helped me see where material was being removed. I kept filing until all the green lines were gone.
So I now see my options as:
  1. Leave things as they are with only the 2mm cork gasket in place since it is working. I do have a concern about the cork material. What is the expected longevity/suitability of cork in this application? Fel-Pro states the material is suitable for Oil, Coolant, Gasoline.
  2. If cork is not suitable, I also have 1mm Rubber-Fiber gasket material that I could cut gaskets from (also suitable for Oil, Coolant, Gasoline), but not sure if the reduced compliance and thickness will seal the leak.
  3. If cork is ok, cut another gasket and place one at both top & bottom of the phenolic insulator (to prevent heat-soaking carbs)
  4. Take both manifolds to a machinist to have them properly milled, assuming the issue is with the manifold, and not the head
  5. Purchase new manifolds (may be cheaper than machining old ones), but what is the chance that they too will need to be machined?
If folks chime in and state cork is ok (at least short-term), then I think I will try option 3 next and stick with that if there are no leaks. Then go the machining route when I drop the motor later this year for a transmission rebuild.
Oh, and btw, what torque spec are folks using for the intake manifold to head studs? I recall looking for this but could not find it. I went with "snug", maybe 10-15 ft-lbs.
VaccaRabite
post Aug 11 2025, 07:25 PM
En Garde!
IMO - that's trash and needs to be milled down flat. I'd use sandpaper on glass over a file, 100 - 400.
Sharpie marker makes a good witness.
That said - cork is FINE. And if it seals, it seals.
Most of the carb gaskets sold are paper, and that would not seal those intakes.
Zach
ChrisFoley
post Aug 13 2025, 05:38 AM
I am Tangerine Racing
A file doesn't work well to flatten over such a large area as that manifold gasket surface. Much better to push against a full sheet of sandpaper mounted to a large, very flat surface.
I've never seen a warped head cause an intake leak but plenty of times I've found traces of old gasket on the head when tracking down a persistent leak.
ChrisFoley
post Aug 13 2025, 05:47 AM
Milling will be expensive due to a challenging setup, and shouldn't be necessary. Hand flattening should be sufficient, but patience and good technique are key.
Al Meredith
post Aug 13 2025, 08:56 AM
I always true the manifold with a belt sander before reusing especially "new" ones. They never seem to flat.
- Lo-Fi Version Time is now: 14th August 2025 - 04:04 AM
