RKramden |
Newbie ![]() Group: Members Posts: 45 Joined: 26-October 19 From: So. California Member No.: 23,589 Region Association: Southern California ![]() |
Finally putting the rear suspension back together and have noticed some play in both hubs. Not in and out, but more like rocking back and forth, side to side. Before I go any further, is this normal and will it go away when the axle hub is torqued down? BTW, these are new bearing, and seem to be seated all the way with the retainers installed. Any insight will be greatly appreciated
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,924 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
needs CV stubs to be torqued to be correct..
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,905 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Finally putting the rear suspension back together and have noticed some play in both hubs. Not in and out, but more like rocking back and forth, side to side. Before I go any further, is this normal and will it go away when the axle hub is torqued down? BTW, these are new bearing, and seem to be seated all the way with the retainers installed. Any insight will be greatly appreciated Yep must be torqued up to the correct value as mentioned ,were the bearing a good tight fit in the trailing arms ? seem to remember reading on here there were some that some were undersize on the O.D. of 75mm but don't remember what brand they were . Cheers . |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,218 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
ALL bearings are NOT created equal. Did write up years ago. Bearing use to only come in one quality, EXCELLENT. Now it seems there are good, better and best. I try and use only SKF made in Spain and Italy. I only use FAG 545495AD made in Canada and Germany. Most of these bearings are from the late 1990's.
RKramden |
Bearing was FAG from 914 Rubber, and went in tight with some med-heavy pulls on the all thread nut with steel angles on either side. I’ll be heading down to my FLAPS store to borrow the mega torque wrench this weekend. If that solves the wobble then it’s off to installing the engine. Thank you all for the input!!
Lo-Fi Version | Time is now: 14th August 2025 - 04:04 AM |
