> 914World Classifieds Rules
> Found! (was WTB: Left front hood hinge assembly), Needed due to DAPO
BillC
post Aug 28 2025, 06:09 PM
Found!
So I'm replacing my front hood gasket and treating the rust in the channel, when I discovered that the DAPO has struck again. (IMG:style_emoticons/default/headbang.gif)
At some point, the driver's side (left) front hood hinge bolt must have broken off, and it was "repaired" poorly. I need a replacement.
Does anyone have a good, stock front left hood hinge assembly for sale? Preferably in Alaska Blue Metallic, but I'll take any color as long as it's in good shape. I'll even take a matching pair, if necessary.
At a minimum, I need the hinge bolt (part #914-512-191-10) and the left-side hood hinge bracket (part #914-511-037-10), which is the part that bolts to the body (the part that bolts to the hood appears to be fine).
Please let me know what you have.
Thanks!
bdstone914
post Aug 28 2025, 09:24 PM
bdstone914
QUOTE(BillC @ Aug 28 2025, 05:09 PM) *
Thanks!
I saw one in the shop but have to check which side it fits.
I have a parts car but it will be at least a couple weeks before I start pulling parts from it. I should have all the hardware
BillC
post Aug 29 2025, 12:17 PM
QUOTE(bdstone914 @ Aug 28 2025, 11:24 PM) *
Thanks!
Unfortunately, I can't really wait a couple of weeks. I'm signed up for an event in a couple of weeks and need to get the car back together before then.
Anyone else have the parts?
post Aug 29 2025, 01:36 PM
914-6 GT in waiting
I’m pretty sure I have some. One side had a bolt break off in the threads but if I remember correctly, that’s probably something you can handle. Free if I have them. Might be a day or two before I check the stash.
I should have the hinge bolt as well.
BillC
post Aug 29 2025, 02:43 PM
QUOTE(mepstein @ Aug 29 2025, 03:36 PM) *
Yup, no problem drilling out a broken bolt and restoring the threads. If I have to, I could fix this one, but it would have to be welded up first -- the DAPO drilled it out off-center, and then jammed an SAE screw into it. Which also explains why the hood never lined up quite right.
sixaddict
post Aug 30 2025, 08:22 AM
Got it!
Pm your number will text pic…..sorry not blue.
Get me info early could go today..
BillC
post Sep 1 2025, 01:39 PM
Bump. Still looking.
In case anyone is wondering, this is what I'm looking for:
post Sep 1 2025, 04:32 PM
914-6 GT in waiting
Lots of searching but this is all I found.
Rob-O
post Sep 1 2025, 06:02 PM
I’m pretty sure I have both sides. Let me check the stash in the morning and I’ll get back to you.
Montreal914
post Sep 1 2025, 06:12 PM
I have this, but it is a lot more than what you are looking for... (IMG:style_emoticons/default/dry.gif)
racer914
post Sep 2 2025, 11:45 AM
Bill
I have what you need. Sending to you free of charge...I feel bad about the bumper problem. I have your address, I'll get it in the mail today.
Best
Dave
BillC
post Sep 3 2025, 10:43 AM
Parts are on the way. (IMG:style_emoticons/default/piratenanner.gif)
Thanks everyone!
- Lo-Fi Version Time is now: 4th September 2025 - 02:18 AM
