| 914ltd |
Sep 22 2025, 05:10 PM
Member ![]() ![]() Group: Members Posts: 245 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None
Porsche 914 1974 2.0 with modifications. 96,216 miles. No apparent previous crash damage, minimal rust damage. Runs and drives great.
Rebuilt engine to performance specs: Mahle European pistons and cylinders, Web 270 Cam and lifters, Balanced and lightened rotating assembly, Improved oil return control to extended sump, Rebuilt and flowed cylinder heads, Weber 44 IDF carbs with cross shaft linkage, 4 into 1 racing headers, MSD ignition. Lightened flywheel, Transaxle rebuilt with short 3rd gear, Weltmeister short shifter. Koni double adjustable performance shock absorbers, Weltmeister 19mm adjustable front sway bar. Five bolt wheel conversion with Etolie 7X15 wheels, 914/6 front struts and brakes, Genuine 914/6 rear calipers with park brake. 21mm torsion bars, front, 160# springs rear, 914LTD chassis stiffening panels. Toyo Azenis 205/50 tires. 916 style front and rear lightweight bumpers, Fenders pulled out and smoothed for clearance, Excellent interior with custom carpet, no cracks in dash, Center console with gauges, Fittipaldi steering wheel. Suspension pick up points are solid. The "hell hole" is great and has not been rebuilt. The rear trunk floor is excellent. Some rust in the front fenders and driver’s door. This 914 was built in my shop 20 years ago. Care was taken to assure a dependable and attractive car was the finished product. Brad Mayeur I'm helping with the sale of this car. The owner can no longer drive. I received the OK to drop the price. This is a great driving car and is very solid except for the aforementioned front wheelhouse corrosion. $21,500 It's worth a lot more! PENDING Attached thumbnail(s) |
| 914ltd |
Oct 19 2025, 06:23 PM
Additional photos.
I'll get more on a Google Photos link. Attached thumbnail(s) |
| 914ltd |
Nov 8 2025, 09:44 AM
Just to note again, the "hell Hole" is perfect ans has not been rebuilt! |
| 914ltd |
Nov 8 2025, 10:23 AM
| 914ltd |
Nov 21 2025, 08:34 PM
Take another look at this car. It is a great 914 for the money. Brad Mayeur
| 914ltd |
Dec 17 2025, 12:18 PM
RUST, OMG! Drivers door and front fender, driver and passenger lower front wheel house and front trunk seal channel. None of this affects the way this incredible 914 runs and drives. Repairs can be planned for the next month, year or decade! I have pictures. Read the description. A lot of desirable improvements are already completed. Chassis stiffening panels. 914/6 front and rear brakes and suspension. Koni double adjustable shocks and struts. 19mm adjustable front sway bar. Weber 44 IDF carbs with cross shaft linkage. Custom 4 into 1 header. Engine rebuilt and modified with planned long term performance and dependability. Beautifully pulled out fenders to clear 7X15 (or larger) wheels/tires. Excellent interior, no dash cracks, Fittipaldi steering wheel, excellent, original seats. No previous crash damage. Excellent front and rear trunk floors. THE "HELL HOLE" IS EXCELLENT AND ORIGINAL. Clean title in hand. $21,500. |
| 914ltd |
Jan 16 2026, 09:41 AM
Read the last post which contains a recap of the features. It would be MUCH less expensive to buy this car and do the repairs and add your own improvements than buy a project 914 to rebuild. |
| 914ltd |
Jan 29 2026, 03:04 PM
I want to keep this car out there as available. It is the "perfect 914" for someone. Brad Mayeur |
| 914ltd |
Feb 11 2026, 09:37 AM
All the mods you would probably add to your dream 914 done.
| worn |
Feb 11 2026, 07:10 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,558 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
| 914ltd |
Feb 24 2026, 02:24 PM
Still available and still a great buy! |
| preach |
Mar 13 2026, 03:15 PM
Ridge Runner ![]() ![]() ![]() Group: Members Posts: 1,071 Joined: 27-March 10 From: Live Free or Die Member No.: 11,513 Region Association: North East States
I just left you a message.
| preach |
Mar 14 2026, 01:35 PM
Please be happy that this car is going to an enthusiast.
Id out to talk to my bank a figure out a wire transfer and get a fligh to Pioria. Then the adventure begins. |
Lo-Fi Version | Time is now: 14th March 2026 - 03:15 PM |
