> valve adjustments
dlindzey
post Oct 12 2025, 06:00 PM
repeat offender
Are the clearances for intake and exhaust valves the same for 1.7, 1.8 and 2.0 engines?
My engine has been modified with a kit to 1.97-big piston kit, would that influence recommended valve clearances?
emerygt350
post Oct 13 2025, 05:54 AM
QUOTE(dlindzey @ Oct 12 2025, 06:00 PM) *
If I remember correctly the 1.8 is different and the kit won't affect the valve adjustment. Things that would are different valves and the addition of hydraulic lifters.
If you know what the heads are from that will likely tell you the required clearance.
Jack Standz
post Oct 13 2025, 07:34 AM
If you are running chromoly pushrods versus aluminum pushrods after the kit install, then there will be changes to the valve lash/clearances.
Chad911sc
post Oct 14 2025, 04:09 PM
If your pushrods are still aluminum, follow the stock guidelines for valve lash. If they are aftermarket chromoly, set them at 0 lash.
brant
post Oct 14 2025, 04:12 PM
It also depends on sodium valves or lack of sodium valves
Really everyone should be recommending either stock or your builders tried and true advice
People on here are generally not experienced from building hundreds of motors and it’s a hodgepodge of some poor advice based on the internet
- Lo-Fi Version Time is now: 15th October 2025 - 10:07 AM
