| JamesJ |
Oct 26 2025, 04:33 PM
Member ![]() ![]() Group: Members Posts: 245 Joined: 30-April 20 From: Sunnyvale, CA Member No.: 24,202 Region Association: Northern California
| mepstein |
Oct 26 2025, 05:22 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,200 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
914rubber should have them.
| JamesJ |
Oct 26 2025, 06:59 PM
| mepstein |
Oct 26 2025, 07:12 PM
| JamesJ |
Oct 27 2025, 10:13 AM
914Rubber and AA don't have them...not sure if Porsche does. Next time I'm at the dealership I'll ask. Good used ones would be fine if anyone has a pair or two.
| jim_hoyland |
Oct 30 2025, 06:44 AM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,930 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
I’d like some too… (IMG:style_emoticons/default/smile.gif)
| GeorgeKopf |
Oct 30 2025, 07:36 AM
Member ![]() ![]() Group: Members Posts: 254 Joined: 9-February 21 From: Princeton, NJ Member No.: 25,186 Region Association: MidAtlantic Region |
Thingiverse has this Targa Trim Button. If this is the same as the bolster trim buttons, I can print some for you.
![]() If that doesn't work, then if somebody sends me the dimensions and a few pictures, I can design and and print them. George |
| JamesJ |
Oct 30 2025, 09:09 PM
| 914ltd |
Oct 31 2025, 06:17 AM
Member ![]() ![]() Group: Members Posts: 245 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None
The 2 side holes in the lower dash and the 2 drivers door pocket are a larger size. I have 4 of them them and 5 of the smaller plugs (you'll need them) that most of the other interior trim require for $30. delivered. I'll post a photo both sizes shortly. Brad
The photo shows both sizes of the screw hole plugs. The smaller appears to be 8mm and the larger is about 11mm (12?) also shown are the plugs for the bolster on the targa top and the plugs for the ski rack under the roll bar. I have all of these but a very limited number of the larger 11mm plugs. Install these with a dab of RTV silicone. Attached thumbnail(s) |
| JamesJ |
Oct 31 2025, 09:34 AM
The 2 side holes in the lower dash and the 2 drivers door pocket are a larger size. I have 4 of them them and 5 of the smaller plugs (you'll need them) that most of the other interior trim require for $30. delivered. I'll post a photo both sizes shortly. Brad The photo shows both sizes of the screw hole plugs. The smaller appears to be 8mm and the larger is about 11mm (12?) also shown are the plugs for the bolster on the targa top and the plugs for the ski rack under the roll bar. I have all of these but a very limited number of the larger 11mm plugs. Install these with a dab of RTV silicone. Sent PM |
| jim_hoyland |
Oct 31 2025, 11:02 AM
Sent PM too…
| 914ltd |
Nov 1 2025, 07:31 AM
| jim_hoyland |
Nov 2 2025, 01:34 PM
PM sent
| GaroldShaffer |
Nov 2 2025, 09:15 PM
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,638 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None
| DC_neun_vierzehn |
Nov 4 2025, 10:45 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 588 Joined: 16-November 20 From: Coastal Delaware Member No.: 24,893 Region Association: MidAtlantic Region
I could use a pair of those larger plugs for the side of the dash. Never knew there were supposed to be plugs there!
Lo-Fi Version | Time is now: 4th November 2025 - 01:56 PM |
