| rick 918-S |
Nov 30 2025, 11:07 AM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,136 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
I am installing new front bushings on the A arms for the 6. I watched several videos on the subject. There was one that even showed a guy wrapping plumbers Teflon tape around the arm and bushings as means of providing a squeak resistant surface. My confusion is the use of grease/Teflon and grease on the outer surface of the bushings. I would think you would want resistance on the outer surface and movement on the inner surface. What is the theory (IMG:style_emoticons/default/confused24.gif)
rick 918-S Front A arm bushing question Nov 30 2025, 11:07 AM
jhynesrockmtn Was that install a non rubber bushing? If stock r... Nov 30 2025, 11:37 AM
rick 918-S I watched Ian's vid
I was going.to ask him if... Nov 30 2025, 12:21 PM
bdstone914
I watched Ian's vid
I was going.to ask him i... Nov 30 2025, 12:29 PM
TheRuttmeister You don't want to use grease on rubber bushing... Nov 30 2025, 12:32 PM
Superhawk996
You don't want to use grease on rubber bushin... Nov 30 2025, 01:26 PM
rick 918-S
You don't want to use grease on rubber bushi... Nov 30 2025, 02:07 PM
TheRuttmeister
Delrin is a "self lubricating" polymer... Nov 30 2025, 02:10 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st December 2025 - 11:30 AM |
