| beltwerks |
Dec 6 2025, 04:15 PM
Newbie ![]() Group: Members Posts: 49 Joined: 14-January 19 From: UK Member No.: 22,800 Region Association: None |
As a newcomer to the world of the 914 i will be asking some rookie questions. (IMG:style_emoticons/default/biggrin.gif)
I'm about to remove the 1.7 engine from my car as i intend to install a 6 engine once restored. Is there anything i need to keep from this engine before i offer it for sale .? Wiring, clutch, flywheel etc. Thanks in advance Dave |
| mepstein |
Dec 6 2025, 04:25 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,588 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I cant think of anything from the engine that gets used for the conversion.
(IMG:style_emoticons/default/welcome.png) |
| 930cabman |
Dec 6 2025, 04:33 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,573 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
A reasonably large bank account to start Dr 914, Auto Atlanta has a booklet describing most of whats required, Pelican also has something It's a process, but keep the questions coming. We will get you through |
| beltwerks |
Dec 6 2025, 05:14 PM
Thanks for the replies, much appreciated. I will keep on reading and try to learn. Now, if anyone wants any seatbelt advice i'm your man.
| Ninja |
Dec 6 2025, 06:33 PM
Member ![]() ![]() Group: Members Posts: 195 Joined: 25-September 25 From: Granbury Texas Member No.: 29,004 Region Association: Southwest Region |
Does the 1.7 run?
I might leave it in to debug the chassis. A Porsche 6 conversion is complicated and expensive. There are more threads regarding these types of conversion here than anywhere else. You've come to the right place... Spend some time going through the threads! |
| sixaddict |
Dec 6 2025, 07:14 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,053 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States
There are many people on here that are far more knowledgeable than I and you have a great start from some of the best. I have done a couple and have a few suggestions.
First is a lot of people have their preferences……motor mounts for example….. You have several choices so do your homework. You also have choices when made early can be easy. There are things people don’t do…..like removal of -4 engine mounts to make it cleaner. Depending on your use street/track or both you have choices on brakes and cooling that are best made early in your build. It’s a matter of how deep you want to go…….Welcome and good luck with your build. Just my 2 cents. |
| mb911 |
Dec 7 2025, 05:16 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,732 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
I can help with questions and parts 914-6werkshop.com
| IronHillRestorations |
Dec 7 2025, 09:54 AM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,927 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
I’ve done a few 6 conversions and always glad to help.
I also make engine harnesses for 6’s and 6 conversions, send me a PM and I can help. |
| mlindner |
Dec 7 2025, 01:35 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,749 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest
Yup, Perry Kiehl for a engine harness...just the best. I would also recommend starting with the basics. In Wisconsin, heated A/C garage, some kind of lift, build box to roll motor and trans into position. Your going to do this a few time to get everything right. And Ben McFarland has all the knowledge as to oil, exhaust, mounting. Then you go to PMB for all the brake upgrades you will want. And 914world will have the rest. Best, Mark
| beltwerks |
Dec 7 2025, 04:30 PM
Thanks for all the advice and offers of help. This build will be a slow burner whilst i learn and read as much as i can.
| 930cabman |
Dec 7 2025, 04:38 PM
Yup, Perry Kiehl for a engine harness...just the best. I would also recommend starting with the basics. In Wisconsin, heated A/C garage, some kind of lift, build box to roll motor and trans into position. Your going to do this a few time to get everything right. And Ben McFarland has all the knowledge as to oil, exhaust, mounting. Then you go to PMB for all the brake upgrades you will want. And 914world will have the rest. Best, Mark Show off!! wish my /6 conversion was this sweet are you toting bags of potatoes for hire these days? |
Lo-Fi Version | Time is now: 4th April 2026 - 07:28 AM |
