| 914xr75 |
Dec 9 2025, 10:53 AM
Member ![]() ![]() Group: Members Posts: 204 Joined: 24-March 18 From: Whittier, CA Member No.: 21,996 Region Association: Southern California |
So when I’m just turning left without applying the brakes, the front and back turn signals work as they should. With the brake applied the turn signals do not blink.
The right side works correctly. It’s a 1973 model. I did install the Spoke led front turn signal boards but I’m not sure if it did the same thing before the LED change. I only noticed because a car behind honked at me when I was turning left. Any ideas for this problem would be appreciated. |
| windforfun |
Dec 9 2025, 11:34 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,091 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None
You might want to reverse the previous surgery. Maybe. IMO, you have to test your changes ASAP.
Happy holidays. (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) |
| DC_neun_vierzehn |
Dec 9 2025, 12:03 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 625 Joined: 16-November 20 From: Coastal Delaware Member No.: 24,893 Region Association: MidAtlantic Region
So when I’m just turning left without applying the brakes, the front and back turn signals work as they should. With the brake applied the turn signals do not blink. The right side works correctly. It’s a 1973 model. I did install the Spoke led front turn signal boards but I’m not sure if it did the same thing before the LED change. I only noticed because a car behind honked at me when I was turning left. Any ideas for this problem would be appreciated. I have a similar issue going on with my front turn signals and parking lights. It happens intermittently - when I'm pulling up to a red light and I'm behind another car, I can see in the reflection of the car in front of me that when I tap the brakes, the parking lights in the turn signal housing go out. When I take my foot off the brake they come back on. Then at other times, the parking lights will stop working while I'm driving and don't come back on (doesn't appear to be effected by braking). I have a hard time re-creating this issue at home in my garage so it's not been easy to resolve. I think I will make it my #1 winter project while it's off the road for a few months. I'll let you know if I have any luck. |
| Ishley |
Dec 9 2025, 01:11 PM
Member ![]() ![]() Group: Members Posts: 324 Joined: 4-October 21 From: Clarendon Hills Il Member No.: 25,957 Region Association: Upper MidWest
Call the spoke guys to see what they say. Here is my thoughts… others may have different ideas.
In general… the LED lights in turn signals draw a lot less power. This affects the flasher… as the flasher technology uses the power to trigger. When your brake lights are off there is enough power going thru the circuit and the flasher pulses correctly. When the brake lights come on… its drawing power over to those lights and away from the turn signals circuit. The flasher then no longer has enough power to pulse. There is a fix… you can search for it. It involves changing the flasher. |
| Ishley |
Dec 9 2025, 01:28 PM
| Dave_Darling |
Dec 10 2025, 02:52 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,326 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
You've got one of the turn signal buckets mis-wired. Could be front, could be rear.
Time to dig into the LED swap you did and carefully check where everything is hooked up. --DD |
| Spoke |
Dec 10 2025, 07:13 AM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,348 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
So when I’m just turning left without applying the brakes, the front and back turn signals work as they should. With the brake applied the turn signals do not blink. The right side works correctly. It’s a 1973 model. I did install the Spoke led front turn signal boards but I’m not sure if it did the same thing before the LED change. I only noticed because a car behind honked at me when I was turning left. Any ideas for this problem would be appreciated. Installing LEDs in turnsignals and brakes won't cause any strange issues unless there are some socket or wiring issues. LEDs will tend to accentuate any wiring/socket issues. Quick question: are the brakes incandescent or LED? The brake light is a combination of running light and brake (dual filament). Likewise the front turnsignal is also dual filament with running light and turnsignal. If the ground is lost on the brake bulb it can cause the running light to power via the brake light through the running light. Ground can be lost on a bulb if the socket and/or bulb base are oxidized. A good cleaning with a small screwdriver to scrape the socket sides and power buttons. Do not press hard on the power buttons. Try this test: remove the brake bulb and see if the turnsignal stops when the brake is applied. |
| Spoke |
Dec 10 2025, 07:20 AM
I have a similar issue going on with my front turn signals and parking lights. It happens intermittently - when I'm pulling up to a red light and I'm behind another car, I can see in the reflection of the car in front of me that when I tap the brakes, the parking lights in the turn signal housing go out. When I take my foot off the brake they come back on. Then at other times, the parking lights will stop working while I'm driving and don't come back on (doesn't appear to be effected by braking). I have a hard time re-creating this issue at home in my garage so it's not been easy to resolve. I think I will make it my #1 winter project while it's off the road for a few months. I'll let you know if I have any luck. Did you change any wiring after you noticed this behavior? Being intermittent it could be oxidized sockets. You can try cleaning all the sockets with a small screwdriver. Bulb bases can be cleaned with steel wool. Do not use steel wool on the sockets; use a small screwdriver and just scrape the surfaces. Try removing the brake bulbs and see if anything changes when applying the brakes. |
| 76-914 |
Dec 10 2025, 09:29 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,865 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
You've got one of the turn signal buckets mis-wired. Could be front, could be rear. Time to dig into the LED swap you did and carefully check where everything is hooked up. --DD (IMG:style_emoticons/default/agree.gif) |
| 914xr75 |
Dec 10 2025, 11:56 AM
Thanks everyone for the suggestions. I will dig into this in a few weeks and let you know what I come up with.
Lo-Fi Version | Time is now: 2nd March 2026 - 10:30 PM |
