| sysintspec |
Jan 5 2026, 04:45 PM
I'm new here ... Group: Members Posts: 0 Joined: 5-February 18 From: New Jersey Member No.: 21,866 Region Association: None |
More stuff from the attic.
Have tach, speedo, fuel gauge from 1973 1.8 Speedometer needs a new trim ring as existing one is dented. $ 240.00 Buyers pays shipping Attached image(s)
| scallyk9 |
Jan 5 2026, 07:02 PM
Member ![]() ![]() Group: Members Posts: 367 Joined: 16-October 16 From: Port Orchard, WA, USA Member No.: 20,499 Region Association: Pacific Northwest
Actually, correct for 70 through 73 1.7 or 2.0
| Montreal914 |
Jan 5 2026, 07:09 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,001 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California
73 model had 1.7 or 2.0 selection. Your speedometer being 150mph means these were from a 2.0 most probably.
The biggest question here is: does the odometer work? One way to test it is to use a square bit in your drill IN REVERSE and insert it where the speedometer cable connects to. Your speedometer needle will get to speed and you should add a mile after a while. Your trip odometer will move too! Good luck with the sale! (IMG:style_emoticons/default/smile.gif) |
| sysintspec |
Jan 6 2026, 08:19 AM
73 model had 1.7 or 2.0 selection. Your speedometer being 150mph means these were from a 2.0 most probably. The biggest question here is: does the odometer work? One way to test it is to use a square bit in your drill IN REVERSE and insert it where the speedometer cable connects to. Your speedometer needle will get to speed and you should add a mile after a while. Your trip odometer will move too! Good luck with the sale! (IMG:style_emoticons/default/smile.gif) You're right .Came from 2.0 Just tested and both speedometer and odometer work. |
| 69146 |
Jan 6 2026, 11:14 AM
I'm new here ... Group: Members Posts: 0 Joined: 18-August 23 From: Oldsmar Member No.: 27,532 Region Association: None |
[quote name='sysintspec' date='Jan 6 2026, 09:19 AM' post='3239699']
[quote name='Montreal914' post='3239641' date='Jan 5 2026, 08:09 PM'] 73 model had 1.7 or 2.0 selection. Your speedometer being 150mph means these were from a 2.0 most probably. The biggest question here is: does the odometer work? One way to test it is to use a square bit in your drill IN REVERSE and insert it where the speedometer cable connects to. Your speedometer needle will get to speed and you should add a mile after a while. Your trip odometer will move too! Good luck with the sale! (IMG:style_emoticons/default/smile.gif) [/quote] You're right .Came from 2.0 Just tested and both speedometer and odometer work. [/quot Would you consider individual sale and if so what would you want for the speedometer? |
Lo-Fi Version | Time is now: 8th January 2026 - 04:06 PM |
