| SKL1 |
Jan 5 2026, 09:52 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,745 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest
Trying to figure out how accurate the OEM voltmeter is in my '73 2.0. To make a long story shorter the engine in the car is a much modified 1.9 from my '71, with approx 120K miles on the alternator.
Voltmeter reads around 11V and drops to 10 if I turn on the headlights. Immediately goes back to 11 or just over that with the lights turned off. Replaced the voltage regulator this AM and did a test drive with no change. Gauge never gets close or above 12V. Makes me afraid to drive it at night with the lights on and go very far. Do I need to go through the hassle of rebuilding the alternator or trying the alternator from the original 2.0 engine that has about 70K miles on it? Better way to get a more accurate reading of actual voltage?? I hate electrical issues!!!! TIA. |
SKL1 Voltmeter reading? Accuracy? Jan 5 2026, 09:52 PM
mjrrti
Trying to figure out how accurate the OEM voltmet... Jan 5 2026, 11:16 PM
mjrrti The brand didn’t show in my pic but it is zeehoo... Jan 5 2026, 11:22 PM
930cabman I have found voltmeter readings somewhat erratic, ... Jan 6 2026, 05:58 AM
emerygt350 It's really not the voltmeter, I checked mine ... Jan 6 2026, 06:36 AM
GregAmy
Trying to figure out how accurate the OEM voltmet... Jan 6 2026, 08:15 AM
SKL1 Thanks. The meter in the lighter sounds great but... Jan 6 2026, 11:47 AM
SKL1 Measured voltage at the battery with a multimeter-... Jan 9 2026, 05:47 PM
Spoke
Measured voltage at the battery with a multimeter... Jan 10 2026, 09:28 PM
Superhawk996 1) Means your battery isn’t charging.
2) Means ... Jan 9 2026, 05:50 PM
emerygt350 It means either the alternator is shot or your vol... Jan 9 2026, 06:09 PM
GregAmy Yup, charging system inop.
Is you GEN light on? Y... Jan 10 2026, 02:39 PM![]() ![]() |
Lo-Fi Version | Time is now: 11th January 2026 - 01:35 AM |
