> Best glue for rear view mirror?
post Jan 11 2026, 09:24 PM
Resident German
I tried 2-part epoxy that is supposedly purpose made for this but it doesn't set up quick enough.
I can't hold the mirror up for 5 minutes perfectly still without moving, which creates a weak bond that fails after a day or two.
914werke
post Jan 11 2026, 11:34 PM
Stock Mirror? Why not use the adhesive pad?
Garland
post Jan 12 2026, 07:28 AM
Restoration Fanatic
Just be sure to use the black colored pad, white one doesn’t look good from the outside.
StarBear
post Jan 12 2026, 08:21 AM
QUOTE(Garland @ Jan 12 2026, 08:28 AM) *
(IMG:style_emoticons/default/agree.gif) use the black pad.
Cairo94507
post Jan 12 2026, 09:22 AM
Michael
With the pad, put it on the windshield first and use a roller to get all the air/bubbles out so it looks nice. Then place the mirror onto the pad. I have never had any luck with the epoxy to attach mirrors. (IMG:style_emoticons/default/beerchug.gif)
GregAmy
post Jan 12 2026, 09:23 AM
I used this over the summer. Cleaned up the base first then roughed up the metal bits for grip.
Fingers crossed, so far so good.
https://www.amazon.com/dp/B000VNAIQ2
post Jan 12 2026, 09:48 AM
Resident German
Sorry, should have mentioned, not a stock mirror, i don't think the pad will work in my application.
Or maybe it will? This mirror is bigger and heavier.
GregAmy
post Jan 12 2026, 10:14 AM
QUOTE(SirAndy @ Jan 12 2026, 10:48 AM) *
What is the pad made of?
If you're looking for a double-sided mounting tape, use 3M VHB (Very High Bond), that stuff is tenacious. I'm told it was designed to install external windows and panels on skyscrapers, and I used it to mount a solar panel on the roof of my RV trailer. It does not come off easily...if at all.
Available in various thickness, width, and length.
post Jan 12 2026, 12:13 PM
Resident German
QUOTE(GregAmy @ Jan 12 2026, 08:14 AM) *
The pad on the mirror is metal ...
Spoke
post Jan 12 2026, 04:28 PM
Jerry
QUOTE(SirAndy @ Jan 12 2026, 01:13 PM) *
The mirror on my 914 is aftermarket and the pad is also metal. I had to remove the pad from the mirror to get the pad glued on. I used something like this for the adhesive.
If the directions say just use 1 drop of adhesive do it. I flooded it with adhesive the first time and it didn't hold.
post Jan 12 2026, 05:33 PM
914-6 GT in waiting
QUOTE(Spoke @ Jan 12 2026, 05:28 PM) *
Exactly what I used on 3-911's last year. put tape besides the old adhesive to keep the location framed, clean with razor blade and their cleaner wipe and then one drop of adhesive. 911 mirrors are a little easier since they have a separate mount that doesn't put torque on the glue while it dries but I've seen all 3 cars over the past couple months and all is good. I pick it up at advance auto.
bkrantz
post Jan 12 2026, 08:02 PM
One thing to check: is the mirror mounting flange curved to match the glass? If not the gap will be uneven, a slight problem with mounting pads and tape, and a bigger problem with glue.
7 User(s) are reading this topic (4 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 12th January 2026 - 08:58 PM
