| fiberglass1inc |
Jan 14 2026, 03:42 PM
Newbie ![]() Group: Members Posts: 16 Joined: 13-April 14 From: WPB Florida Member No.: 17,248 Region Association: None |
Hello 914 brothers and sisters! I have a 73 914 with a 75 engine. Had some issues with the light switch which I believe is a 75 switch (12 pin, the 73 switch is 9 pin). When the turn signals are used they don't work and the low oil pressure light comes on (pressure is not low). This is recent, always worked before. Has anybody seen anything like this? Thank you in advance.
| JeffBowlsby |
Jan 14 2026, 04:17 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,162 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Headlight switch? The 73 switch should be a 10-pin, the 75 switch is an 11-pin.
They are functionally identical, doubt the headlight switch is the cause of the issue you are experiencing. |
| emerygt350 |
Jan 14 2026, 04:47 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,446 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Grounding issue?
Lo-Fi Version | Time is now: 15th January 2026 - 08:25 AM |
