> What do I have here..., Clutch PP TO bearing question
Speedo
post Jan 17 2026, 12:52 PM
Background...bought my 6 10 years ago with a 2.7 and the original 2.0. The 2.7 went away. Getting ready to install original trannie and a 2.4 MFI engine. 2.4 engine does not have a flywheel. Original 2.0 engine has a later flat 6 bolt flywheel (which confuses me) from a 915. The 914 trannie should have the 215 dished flywheel with the starter ring on it, not the flat 225 flywheel. This car was auto crossed most of its life. Was a 225 later flywheel, PP and TO bearing a common upgrade to 914 trannies for bigger engines back in the day? Here is the flywheel...Attached Image
sixnotfour
post Jan 17 2026, 01:24 PM
lets see your trans ..maybe a pull clutch type.. It was an autocross 914 ,,way back ,,I saw it 2 PCA parade events..
Speedo
post Jan 17 2026, 04:50 PM
Ok, here is my trannie...looks like a std push into the PP.
sixnotfour
post Jan 17 2026, 07:00 PM
You're right.. you need a flywheel and clutch...
Does not need to be a 914-6 flywheel... Because the timing marks are going to be off because of the 2.4 crankshaft..
- Lo-Fi Version Time is now: 17th January 2026 - 11:39 PM
