> Clutch Cable Install, How not to explode in a fit of rage
Uraquan
post Jan 27 2026, 10:19 AM
This is for anybody else doing a clutch cable install or adjustment. If you bought a new pin for the clevis at the pedal cluster, make sure that the pin goes through both sides.
I fought with this thing for hours thinking that I was just angling it wrong or something. I finally had enough and said to myself it can't be this hard. Tested the pin and the clevis outside the tunnel and sure enough it would only fit through one side. The old one fit through both sides no problem. So used a file to open the stubborn hole just a little bit and had that cable installed in seconds.
TL:DR test the pin and clevis outside the car before attempting install.
slapshot
post Jan 27 2026, 02:54 PM
That's good to know. Thanks
I just replaced mine after I had to trailer the car home. In my case, the clutch tube broke free and tore the firewall. For those still needing to replace theirs, I’d recommend reinforcing the firewall around the tube while the cable is out—especially if there’s any sign of softness—and checking the clutch tube welds both at the firewall and near the shifter.
914Sixer
post Jan 27 2026, 02:59 PM
Wecome the the world of AFTERMARKET CRAP. They seem to be able to NOT check anything for proper fitment.
worn
post Jan 27 2026, 09:28 PM
QUOTE(914Sixer @ Jan 27 2026, 12:59 PM) *
Which assumes that the manufacturer knows what they are making. We put in holes, no one told us anything about a pin.
porschetub
post Jan 27 2026, 11:39 PM
QUOTE(worn @ Jan 28 2026, 03:28 PM) *
I used a genuine part and it fitted great no problem ,however the replacement cable was rubbish that also came from Pelican ,ended up fitting the OG cable and sorted it after 300 miles of issues .
- Lo-Fi Version Time is now: 28th January 2026 - 06:46 AM
