> 914World Classifieds Rules
> WTB - 2.2L Twin Plug T6, Looking to see what it would cost to source this motor
Jeff_72
post Jan 29 2026, 05:58 PM
I know that there are a ton of options out there, but seeing the number of these motors that are listed in the Roll Call 914 6 GTs thread, I am wondering if one of you could give me an estimate on what these motors are worth, or what it cost you. Im currently looking at this motor for my Outlaw restomod and the cost im being quoted is comparable to a brand new Honda Civic Si.
If thats correct, then im (IMG:style_emoticons/default/sad.gif) but not deterred.
If you have one or similar for sale id be interested in talking.
post Jan 29 2026, 08:06 PM
914-6 GT in waiting
There’s no one price for what you are asking until you get more specific.
Mag or aluminum case
New Mahle p&c’s or refurbished steel
Induction-carbs, FI, itb’s
Twin plug dizzy or coil on plug.
Finding a pre built vs building from scratch vs modifying a running engine
Find a running engine - $20 ish
Build one - $40-60k
Labor is pretty much the same for any engine.
Parts aren’t all that different no matter what size engine you build.
There’s no way to build an engine cheap. I have about 10 engines in the shop right now and more in the queue. It takes a good 100 + hours to break down, clean, measure, build, etc, etc. Add more hours for tuning and some additional depending on how custom the wire harnesses need to be. So multiple your engine building hourly rate by 100. Add up parts. Add in exhaust, powder coating, plating, refinishing and extras. $$$
Jeff_72
post Jan 30 2026, 12:47 PM
Thats exactly what I was looking for. I know the options all have a different cost. What I am being quoted is in the range you provided.
For more info, here is what I am looking at. This is a 4 to 6 conversion so I need new Alternator, Pulleys, Fan and Fan Housing
PMO Induction Complete 40mm Carb Set
Clewett Engineering Crank Fire Complete Kit
New Headers
dug
post Jan 30 2026, 01:17 PM
914-6 conv in progress
You will spend another $2-5k (or even 10) for fuel and oil plumbing depending on parts choices. The factory put an external oil cooler on the 2.2S and the GTs. Once you spend that much on the engine...
mlindner
post Feb 1 2026, 06:02 AM
My 2.2 E with S pistons, DC30 Mod-solex cams , 40 PMOs and Bens header. I do not have external oil cooler, engine never gos over 200 deg. Just FYI
daytona
post Feb 1 2026, 06:36 AM
daytona
Jeff_72, if you decide to build one, I have a 2.2L S long block (not a twin plug) that would be a good start. This is a plug and play after you add the induction parts. This engine came in my 914 six conversion. I removed it to install a 3.0L.
post Feb 1 2026, 07:13 AM
914-6 GT in waiting
QUOTE(daytona @ Feb 1 2026, 07:36 AM) *
Ben might be interested if the OP isn’t.
@MB911
mb911
post Feb 1 2026, 07:38 AM
QUOTE(mepstein @ Feb 1 2026, 05:13 AM) *
@MB911
Yup I have a client looking.
mlindner
post Feb 1 2026, 07:42 AM
QUOTE(mepstein @ Feb 1 2026, 07:13 AM) *
@MB911
Yup, thats what I started with...2.2 long block, then PMOs Cams, shroud, Alt, distributor, engine harness. I did not have to open case, all in I'm $16,000.
post Feb 1 2026, 11:21 AM
I'm new here ...
What are you asking for it?
Jeff_72
post Feb 2 2026, 06:35 PM
I have a good magnesium block motor ready to be re-built. Looks like you might have a buyer for yours though.
Thanks everyone.
- Lo-Fi Version Time is now: 4th February 2026 - 08:11 AM
