| rosenfe |
Feb 5 2026, 11:44 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 565 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None |
I’ve read 2.0
Has 4.8-5.3 oil capacity vs less in the smaller engines. If so do are dipsticks different to account for that |
| wonkipop |
Feb 5 2026, 01:16 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,379 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
according to my factory manual.
same capacity for 2.0 and 1.8 3.5 liters with filter change. one dipstick listed in the parts catalogue for all. # 022 115 611. |
| Dave_Darling |
Feb 7 2026, 12:52 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,321 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
All of the stock four-cylinder 914s had an oil capacity of a bit under 4 quarts. I believe it was 3.5 liters, which is about 3.7 quarts. 914s don't seem to mind having slightly too much oil, so just dumping 4 quarts in when you do an oil (and filter) change works fine.
Note that deep sumps, "tuna cans", external oil coolers, and so on will add to the oil capacity. But it may be harder to get the oil out of some of those while doing a regular oil change. --DD |
Lo-Fi Version | Time is now: 7th February 2026 - 09:12 AM |
