> Broken Hand Brake
LefthandRev
post Feb 5 2026, 01:30 PM
Hi, all.
I pulled my hand brake to park on a hill. When I pulled it up, the button, shaft, and spring shot out like a rocket. No more hand brake! Started looking closer at it and there doesn't seem to be an easy way to fix or replace it - the brake is riveted to the tub and the fatigued shaft just gave up the ghost.
What options do I have here?
It's a '74, if that matters.
Spoke
post Feb 5 2026, 02:06 PM
Jerry
Everything wrt the e-brake comes off with nuts and bolts. Figure out what part broke and replace it.
A single cable from the handle goes to an equalizer to 2 cables; one to each side. Might be time to inspect and replace any other components which look worn/broken.
fiacra
post Feb 5 2026, 11:48 PM
Person.Woman.Man.Camera.TV. = MCI
Can't be sure from your description, but this might just be the parking brake button coming unscrewed. If the parking brake button comes unscrewed the rod and spring can come out of the handle. Didn't know that button had to be checked for tightness until that happened to me. Now every now and then I make sure it is still tight. If that's what happened the fix is easy. Put it back together and screw the button back on (unless the threads on the button have stripped). Diagrams are in the PET
LefthandRev
post Feb 6 2026, 11:25 AM
QUOTE(fiacra @ Feb 5 2026, 09:48 PM) *
my god, man. if i could buy you a beer...
Not only was this it, I was able to tighten it down and the lever works perfectly again. for a few years it's just been wonky and wouldn't catch. I checked the cable tension, connections, everything.
When it died, I thought, "well, it must have been metal fatigue" and that something broke causing the button and spring to fly out like a rocket.
I feel like a dolt. thank you!
fiacra
post Feb 6 2026, 04:26 PM
QUOTE(LefthandRev @ Feb 6 2026, 09:25 AM) *
Glad that was it. Thanks for the beer ! (IMG:style_emoticons/default/beer3.gif)
rgalla9146
post Feb 6 2026, 07:39 PM
Now that you are relieved....when you have the time, take the seat out and disassemble the whole affair.
Check for worn and loose parts, lubricate and reassemble to avoid future surprises.
And remember 'oben' means above, or up.
- Lo-Fi Version Time is now: 7th February 2026 - 09:14 AM
