> Door Glass Removal
nmkimosabe
post Feb 16 2026, 11:24 AM
As a 914 newbie does the entire regulator need to be removed in order to remove the glass or can the forward bolt & plastic block that lifts the window be removed and the window carefully angled to remove it? I need to replace the forward channel guide fuzzy and I don't think it can be done with the window in place.
Ishley
post Feb 16 2026, 11:59 AM
https://youtu.be/TMQt5OYOdqQ
The glass can be removed without taking the regulator out. There are two different doors… 70-72 and 73-76. The YouTube video is the later… and is an assembly video but should tell you what you need to know. I Always suggest stating the year of the car on a post as there are differences by year.
nmkimosabe
post Feb 16 2026, 12:02 PM
QUOTE(Ishley @ Feb 16 2026, 10:59 AM) *
nmkimosabe
post Feb 16 2026, 12:03 PM
Thanks Ed for the suggestion and my car is a 1974 1.8. I will search YouTube for the video.
nmkimosabe
post Feb 16 2026, 02:11 PM
I watched the video, but it looks like Ian took the regulator and the guides out first and then reinstalled everything including the glass.
Ishley
post Feb 16 2026, 02:18 PM
Yes but the glass goes in last… so in reverse order you can take the roll up window out and then get to the guide. I assume you’re talking about the rear guide. The front guide is part of the triangle window.
nmkimosabe
post Feb 16 2026, 02:35 PM
Understood and it's the channel insert that is missing in the front guide that is also supports the vent window. I need to insert a fuzzy in the guide and was hoping not to have to remove the window. Thanks.
TonyA
post Feb 16 2026, 03:08 PM
Nachmal
Be careful with that front adjusting screw. If I am not mistaken you could turn it to far and dent the door. Guys am I correct on this ?
nmkimosabe
post Feb 16 2026, 05:29 PM
I could possibly see that happening, but I think I've found the sweet spot on mine and there's plenty of clearance. Appreciate the heads up.
Ishley
post Feb 16 2026, 09:02 PM
Once you get the window out… you’ll find it might be easiest to just remove the regulator to get the new weather stripping in there. Try to get it in and if it’s too tight pull the regulator.
- Lo-Fi Version Time is now: 16th February 2026 - 11:10 PM
