> Push rod tubes?, OEM or High tech?
robkammer
post Feb 16 2026, 03:43 PM
Robbo
All: I'm wondering what the general consensus is regarding new tubes. Hoping it's not a Ford vs Chevy thing. I pulled the engine primarily to address the weeping and dripping. The old tubes are bent a bit. Probably me. The car is an LE if that matters, should I go with OEM style and new seals? Or the Tangerine type that is a bit more dough but professes to not leak at all.
Also, does anyone out there have a replacement for this piece of engine tin? The AC installation crew did a number on it.
Robbo Attached Image
porschetub
post Feb 16 2026, 05:48 PM
QUOTE(robkammer @ Feb 17 2026, 10:43 AM) *
Stock oem ones are great , member on here bdstone (bruce stone ) often sells quality repaired/and replated ones for a great deal ,cheers.
Jack Standz
post Feb 16 2026, 05:54 PM
Stock Type IV pushrod tubes are sooooooo much better than Type 1 tubes.
Go with tubes you like. For example, if you spend a lot of time under your car looking up at them, the stainless steel ones "spark joy". However, for ones that don't leak, install them with viton seals and a slippery sealant that helps prevent cutting the seal. Stock tubes can be installed without leaks, which is probably the most important part for most people; unless of course you like looking at those shiny aftermarket ones (IMG:style_emoticons/default/biggrin.gif) .
If you are running a stroked crankshaft and therefore have made your engine wider, remember to get either spacers or longer pushrod tubes.
2 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
1 Members: Spoke
- Lo-Fi Version Time is now: 16th February 2026 - 11:11 PM
