> one side magnesium case on the other side aluminum?
wes
post Feb 25 2026, 06:28 PM
wes
Well I got this great deal on 2.0 case except with my excitement and lack of knowledge is it possible said case is actually one side aluminum as was told and the other side magnesium? If so, what heck can I do with it?Attached Image
wes
post Feb 25 2026, 06:30 PM
wes
Superhawk996
post Feb 25 2026, 07:30 PM
Both case halves are magnesium. 2R case vs 3R case.
Unfortunately it’s not a great plan to be mix and matching case halves. There are multiple reasons for this. Probably not worth going into details here but case halves are machined as a pair. You can’t just mix and match two separate case halves without line bore, and incremental machine work.
Sorry to be the bearer of bad news. Even if you went to the trouble of doing the machine work, any future buyer would be suspect of the mismatched case halves.
Would make for a great coffee table. (IMG:style_emoticons/default/confused24.gif)
Perhaps I’m off my rocker and others will correct me.
edit: you could do a quick check - case 1/2’s are factory stamped as a matched pair (ex: 931, 123, etc) before they are machined to keep them in matched pairs. You could check to see if both 1/2s have the same number and came from factory as a 2R/3R pair.
Another tell: early cases don’t have oil squirters. Are both 1/2’s the same (ie no squirters) on both 1/2’s?
wes
post Feb 25 2026, 07:49 PM
wes
QUOTE(Superhawk996 @ Feb 25 2026, 05:30 PM) *
Another tell: early cases don’t have oil squirters. Are both 1/2’a the same (ie no
Where would I find that number?
davep
post Feb 25 2026, 07:55 PM
914 Historian
A 2R/3R case combo is normal. See this thread of mine:
https://www.early911sregistry.org/forums/sh...-case-Revisions
The mating numbers are on the top about middle on the case stud bosses
post Feb 25 2026, 07:58 PM
914-6 GT in waiting
Top of the case halves at the seam.
I agree, if the case halves don’t match, it’s better as a coffee table than an engine build.
I’m not sure of the big picture but buying an engine a piece by piece, is definitely the most expensive way to build an engine.
wes
post Feb 25 2026, 08:03 PM
wes
Is this possibly the number?Attached Image
Superhawk996
post Feb 25 2026, 08:10 PM
QUOTE(davep @ Feb 25 2026, 09:55 PM) *
@daveP help me here
Is 2R / 3R “normal” or is this more of a situation where the factory revised one side before the other?
I know I have a 7R (73.5’ 2.4L) pair but perhaps that’s more a unique situation of 7R being the end of the line for the mag cases and the two halves were both at the same revision simultaneously?
Similarly I always thought / read the 3R cases were largely equipped with oil squirters vs the early 2.0l 2R cases without?
Even in the Bruce Anderson book this is all pretty fuzzy.
Want to learn more.
Note: cool Matrix - hadn’t seen that before. I guess coincidental I’ve only seen 2R/2R or 3R/3R matched pairs - I’m defiantly not well versed on nuances of 911 history.
wes
post Feb 25 2026, 08:11 PM
wes
Relief!Attached Image
davep
post Feb 25 2026, 08:14 PM
914 Historian
No, that is your engine serial # 6404466. It is a type 901/38 engine for a 1970 914/6 North American markets. That matches with the 2R / 3R case combo for 1970.
post Feb 25 2026, 08:19 PM
914-6 GT in waiting
Now find the owner of the car it came in and sell it for $$$
Superhawk996
post Feb 25 2026, 08:20 PM
QUOTE(wes @ Feb 25 2026, 10:11 PM) *
(IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/smilie_pokal.gif)
Sorry for the bad advice when I didn’t have all my facts squared up.
davep
914 Historian
QUOTE(Superhawk996 @ Feb 25 2026, 09:10 PM) *
@daveP help me here
I know I have a 7R pair but perhaps that’s more a unique situation of 7R being the end of the line for the mag cases and the two halves were both at the same revision simultaneously?
Want to learn more.
Yes, you need to study my thread (post 5) on Early 911S Registry. The R's (revisions) tell the story of constant improvement.
Superhawk996
post Feb 25 2026, 08:29 PM
QUOTE(davep @ Feb 25 2026, 10:20 PM) *
Bookmark added.
Thank you Dave for that history lesson. (IMG:style_emoticons/default/pray.gif)
post Feb 25 2026, 08:52 PM
Resident German
QUOTE(mepstein @ Feb 25 2026, 06:19 PM) *
Find the original car this goes with and sell the lot for big bucks ...
(IMG:style_emoticons/default/king.gif)
PS: Looking through the VIN database, the original car should be somewhere around VIN 914.043.0750
PPS: Also found this thread:
http://www.914world.com/bbs2/index.php?sho...&hl=6404466
4 User(s) are reading this topic (1 Guests and 1 Anonymous Users)
- Lo-Fi Version Time is now: 26th February 2026 - 08:26 AM
