> AI Tools for D-Jetronic Instruction, Learn about how D-Jet works faster
pbanders
post Feb 26 2026, 11:32 AM
Example of using Perplexity to understand how the MPS operates. Not perfect, but gives you an idea of what can be done.
https://www.perplexity.ai/search/how-does-t...ue3_8lIh9rqNQ#2
This was the query:
"How does the pressure sensor used in the Bosch D-Jetronic fuel injection system work? Be detailed in describing how it operates at idle, part-load, and full-load conditions."
To improve on the quality of the response, you can combine Perplexity with NotebookLM to cherry-pick the sources you want to use for the topic. This prevents unreliable sources being used, and extends the types of sources.
This concept can be used for a huge number of topics.
Superhawk996
post Feb 26 2026, 12:42 PM
I know AI is unstoppable . . .
But it is hilarious that it’s just scraping jetronic.org and that you have to coach it.
Frankly it should also be scraping your site.
Interesting attempt though. (IMG:style_emoticons/default/beerchug.gif)
worn
post Feb 26 2026, 08:23 PM
QUOTE(pbanders @ Feb 26 2026, 09:32 AM) *
This was the query:
I am impressed. I have to say though that this is one of the biggest challenges I have seen for AI. Compared to the writing of selfless engineers such as some unknown Anders, the description seems a bit, well a bit lame. I am certain that the processors sweated bullets trying, but the bar (or Torr or some such measure) is set awfully high.
- Lo-Fi Version Time is now: 27th February 2026 - 08:53 AM
