| sixaddict |
Feb 26 2026, 08:27 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,043 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States
Working on installing 930 valve covers on a 6 conversion.
I need dimensions of the cut that needs to be made to make it work. Picture would also help either posted or emailed. Thanks in advance. |
| mepstein |
Feb 26 2026, 09:22 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,483 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
If you sand off 5/16" from the fins, it fits.
| gereed75 |
Feb 26 2026, 09:30 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,419 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States
See if this link works
http://www.914world.com/bbs2/index.php?act...t&id=881470 It can be done with a Dremel. |
| sixaddict |
Feb 26 2026, 10:11 PM
Perfect….thanks
| fixer34 |
Feb 26 2026, 10:39 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,394 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest
| 914043 |
Feb 26 2026, 11:25 PM
Member ![]() ![]() Group: Members Posts: 102 Joined: 2-April 19 From: California Member No.: 23,007 Region Association: Central California
| mepstein |
Feb 27 2026, 06:44 AM
So does removing a small area retain strength or create a stress riser vs sanding the entire top the same amount.
| fixer34 |
Feb 27 2026, 08:13 AM
So does removing a small area retain strength or create a stress riser vs sanding the entire top the same amount. Well, I'm not a metallurgist but those pictures were taken 11 years ago, the covers are still on the engine, and I haven't had any leaks yet... Since the idea of the ribbing is to add overall rigidity to the covers, I would think taking almost half off the entire thing would have more of an impact. Just my 2 cents... |
Lo-Fi Version | Time is now: 27th February 2026 - 08:53 AM |
