> Moving a roller with no bumpers on a Uhaul trailer, Will it fit on a 6x12 utility trailer w/ a ramp?
914outlaw
post Feb 28 2026, 09:41 PM
Dave
Has anyone moved a 914 like this?
post Feb 28 2026, 10:40 PM
914-6 GT in waiting
What weight is the trailer rated to? Single axle? Is it long enough to close the gate? Why not rent a car hauler?
Unobtanium-inc
post Feb 28 2026, 11:32 PM
If you put it on a cart that places it above the rim of the trailer only the cart has to fit the trailer.
914werke
post Mar 1 2026, 12:46 AM
Flat tow
http://www.914world.com/bbs2/index.php?showtopic=294018
930cabman
post Mar 1 2026, 06:52 AM
U Haul, roller = no problem
I have done it several times, my wife doesn't agree, but it will work easily. I have used a cheapie come along to pull the hulk onto the trailer
#1 be safe
sixaddict
post Mar 1 2026, 07:12 AM
The U-Haul car hauler is not expense ( seems like $59 a day last time I used one.
Don’t do a one way …..it gets more expensive that way.
post Mar 1 2026, 07:35 AM
914-6 GT in waiting
QUOTE(sixaddict @ Mar 1 2026, 08:12 AM) *
Before I had an aluminum trailer, I used to use them all the time. $60 ish for the day. I’d often pick up in the evening the day before and not get charged extra. Only downside is there’s no winch.
Spoke
post Mar 1 2026, 07:59 AM
Jerry
Transported a no-op 914 with a Uhaul trailer. The only issue was getting the 914 on the trailer when there were just 2 of us. I ended up buying a crank winch from HF and bolted it to the trailer. Pulled the 914 on the trailer no problem.
infraredcalvin
post Mar 2 2026, 05:10 AM
Distracted Member
I forget the size of the uhaul (i think this was a 6x12), but i transported a tub once on a flatbed with no ramp. put it on furniture dolly’s…. Two of us picked up the front, suit it on a furniture dolly’, then picked up the back and slid it in. i took it off by myself with a floor jack. I’ve also used HD ratchet straps to winch a heavy car on a trailer or up lift ramps. Use 2 so when you run out of winding slack, you don't have to chalk the tire to reset the slack. It was not easy, but doable. A winch/come-along would’ve been much easier, but i used what i had…
infraredcalvin
post Mar 2 2026, 05:11 AM
Distracted Member
sixaddict
post Mar 2 2026, 07:43 AM
A trick I’ve learned, buy a portable winch (Walmart or) and use a jumper box to power it.
Always good to have in car guys tool/equipment mix.
billh1963
post Mar 2 2026, 07:47 AM
Car Hoarder!
Rent a u-haul car hauler.
Buy this winch (or equivalent)https://www.harborfreight.com/2500-lb-atvutility-winch-with-wire-rope-and-wireless-remote-control-56258.html and the associated base plate.
Use a heavy duty strap to attach the winch to the trailer. Hook up a battery and go for it. Because you are dragging and not dead lifting the winch is plenty strong. I have moved several heavy cars with locked up wheels with no problem.
I have used that technique multiple times and have shared the idea with lots of people and it has always worked extremely well.
- Lo-Fi Version Time is now: 2nd March 2026 - 09:04 AM
