> Generator light on, What triggers this?
Flyinlow
post Mar 12 2026, 05:51 PM
Flyinlow
Hi.. what would be a reason why my generator light stays on when running?1974 2.0 T.I.A. Dennis
emerygt350
post Mar 12 2026, 06:31 PM
Could be as simple as a slipping belt or failed voltage regulator. Or more complicated, bad wires and ground issues with the alternator or failed alternator.
Flyinlow
post Mar 12 2026, 06:58 PM
Flyinlow
Thanks I’ll keep checking. Dennis
Dave_Darling
post Mar 13 2026, 12:20 AM
914 Idiot
If the tach also doesn't read, it's fuse #8.
--DD
Flyinlow
post Mar 13 2026, 07:44 AM
Flyinlow
QUOTE(Dave_Darling @ Mar 12 2026, 11:20 PM) *
--DD
Tach is fine… thanks for your reply
Spoke
post Mar 13 2026, 11:46 AM
Jerry
QUOTE(Flyinlow @ Mar 12 2026, 07:51 PM) *
Did this just start happening?
Is the belt on and tight?
With the engine running, measure all 3 wires for the alternator at the relay board connector to chassis ground. This will tell a lot of what is going on.
D+ should be 14V
DF should vary between 4-9V
D- should be zero
Vbattery should be 14V
Flyinlow
post Mar 13 2026, 06:24 PM
Flyinlow
QUOTE(Spoke @ Mar 13 2026, 10:46 AM) *
D+ should be 14V
D- should be zero
I will do all of that thanks!
- Lo-Fi Version Time is now: 14th March 2026 - 03:22 PM
