> Easiest Oil Temp Sender Plate oil leak fix ever, DAPO content
914rrr
post Mar 14 2026, 08:31 PM
Finally getting somewhat settled enough in my new workshop / mancave in McMinnville, TN to FINALLY do some work on the teener. Just from setting in place for 3-ish weeks made a pretty big oil leak mess. Oil was dripping out of both oil, temp plate bolts.
After cleaning up the mess, I figured I'd try backing one of the bolts out to inspect the washer / crush ring. Turns out the DAPO used steel split lock washers instead !!! (IMG:style_emoticons/default/slap.gif)
I reinstalled the bolts one at a time with the copper crush rings and it completely cured my oil leak! (IMG:style_emoticons/default/aktion035.gif)
Pic of offending washers and new crush rings installed on the bolts below.
- Lo-Fi Version Time is now: 15th March 2026 - 05:09 AM
