| Fazasport |
Mar 25 2026, 06:29 AM
Newbie ![]() Group: Members Posts: 9 Joined: 7-November 23 From: Tallahassee FL Member No.: 27,713 Region Association: South East States |
Rich - What is the recommended sealant for attaching the extension tube to the existing oil pick up tube.
Is there a curing time for the sealant before assembling the remaining tuna can components. |
| 914werke |
Mar 25 2026, 07:13 AM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,634 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
I use Locktite 515
| FlacaProductions |
Mar 25 2026, 08:57 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,185 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
I used Permatex 29132 and let it sit overnight just to be sure.
| 914werke |
Mar 25 2026, 11:08 AM
.. there is no wrong answer (unless you are using KY lube or something equally ridiculous) the point of the sealant is to ensure any small discrepancy's between the stamped steel pickup tube & the machined steel extension dont leave any gaps. Ive found I often need to "dress" the PU tube with a fine file for fitment
| type2man |
Mar 26 2026, 01:12 AM
Member ![]() ![]() Group: Members Posts: 355 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
Rich - What is the recommended sealant for attaching the extension tube to the existing oil pick up tube. Is there a curing time for the sealant before assembling the remaining tuna can components. Hondabond. It does not dilute or separate like any permatex product. |
| DRPHIL914 |
Mar 26 2026, 02:27 PM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,917 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
hm, installed mine originally and was on therer for 5 years , didnt use anything, and reinstalled it on my new motor recently as i will be doing some AX and also didnt use anything, so i guess on the next oil change i iwill pull this and reinstall with sealer but i had no idea.....
(IMG:style_emoticons/default/chair.gif) |
| 914werke |
Apr 20 2026, 07:28 AM
hm, installed mine originally and was on there for 5 years , didnt use anything, and reinstalled it on my new motor recently as i will be doing some AX and also didnt use anything, so i guess on the next oil change i iwill pull this and reinstall with sealer but i had no idea..... (IMG:style_emoticons/default/chair.gif) good on ya. (IMG:style_emoticons/default/beerchug.gif) Not every (PU) is gonna need it, its just a precaution. The OG steel units from Welt used an oversized Alum tube that was O-ringed to make that seal. Worked well enough but as you can imagine it was necessary to replace that O-ring on occasion. (IMG:style_emoticons/default/dry.gif) |
Lo-Fi Version | Time is now: 21st April 2026 - 03:59 AM |
