| bdstone914 |
Mar 26 2026, 09:57 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,342 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Ready for production. See this thread for updates.
http://www.914world.com/bbs2/index.php?sho...=378681&hl= I have a quote to get 914-6 bell cranks remade. Baded on initial quotes. I could retail them for about $60. I also can make them with a ball bearing in place od the attachment for the carb linkage rod. I would need to made a new design rod to work with it. Also looking an making the accelerator cable bracket that attaches to the trans. The problem i see with the wire loop rod is wear at the 180 bend. A ball bearing would eliminate the wear. Whos in? |
| Luke M |
Mar 27 2026, 04:33 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,563 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States
I have a quote to get 914-6 bell cranks remade. Baded on initial quotes. I could retail them for about $60. I also can make them with a ball bearing in place od the attachment for the carb linkage rod. I would need to made a new design rod to work with it. Also looking an making the accelerator cable bracket that attaches to the trans. The problem i see with the wire loop rod is wear at the 180 bend. A ball bearing would eliminate the wear. Whos in? Hi Bruce, I'd be in for two of the transmission end with the ball bearing. |
| sixaddict |
Mar 27 2026, 07:55 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,082 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States
I would do 1.
| Montreal914 |
Mar 27 2026, 08:31 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,177 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California
I need an accelerator cable bracket. (IMG:style_emoticons/default/smile.gif)
| racer914 |
Mar 27 2026, 11:43 AM
Member ![]() ![]() Group: Members Posts: 111 Joined: 1-October 19 From: Keystone Heights, FL Member No.: 23,513 Region Association: South East States
I'd be in for one or two
| scrz914 |
Mar 27 2026, 01:40 PM
Member ![]() ![]() Group: Members Posts: 452 Joined: 21-April 04 From: Santa Cruz, CA Member No.: 1,960 Region Association: Central California |
I’m in for one. Can you post a picture of the linkage you also mentioned.
The bell crank is a much needed item at an affordable price. |
| markhoward |
Mar 27 2026, 04:38 PM
Member ![]() ![]() Group: Members Posts: 407 Joined: 5-March 17 From: Lafayette, CA Member No.: 20,897 Region Association: Northern California
Interested in one
| Nate W |
Mar 27 2026, 08:48 PM
Member ![]() ![]() Group: Members Posts: 106 Joined: 23-February 21 From: Oceanside, Ca Member No.: 25,250 Region Association: Southern California
I would also be interested in both the Bellcrank and the transmission bracket
| 914Wes |
Mar 27 2026, 08:57 PM
Member ![]() ![]() Group: Members Posts: 56 Joined: 9-March 22 From: SO CAL Member No.: 26,388 Region Association: Southern California |
There will be several parts of this setup we are in the process of having made. The original style bellcrank,
original style throttle rod aka coat hanger, throttle cable bracket on trans, Upgraded bellcrank with bearing along with the matching upgraded rod with clevis. These will all be small batch runs. Will update with pricing for those other items once we have more information available. -Wes |
| live free & drive |
Mar 28 2026, 11:02 AM
Member ![]() ![]() Group: Members Posts: 216 Joined: 29-June 16 From: New Hampshire Member No.: 20,159 Region Association: None
I need the entire set-up too:
original style throttle rod aka coat hanger, throttle cable bracket on trans, Upgraded bellcrank with bearing along with the matching upgraded rod with clevis. |
| mate914 |
Mar 29 2026, 07:02 AM
Matt ![]() ![]() ![]() Group: Members Posts: 951 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States
Im in for a set up also.
Matt |
| rick 918-S |
Mar 29 2026, 08:03 AM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,313 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
(IMG:style_emoticons/default/thumb3d.gif) +1
| mepstein |
Mar 29 2026, 08:08 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,841 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Bruce, I’ll take two compete sets. Thanks
| pencap914 |
Mar 31 2026, 12:03 PM
Member ![]() ![]() Group: Members Posts: 81 Joined: 16-April 06 Member No.: 5,872 Region Association: Northern California |
Hi Bruce,
Count me in for a setup. Thanks! |
| yellowporky |
Mar 31 2026, 08:29 PM
Member ![]() ![]() Group: Members Posts: 445 Joined: 18-October 09 From: Martinez, Ca. Member No.: 10,948 Region Association: Northern California |
Bruce, put me on the list
Thanks Chris |
| Niklas |
Apr 1 2026, 02:56 AM
Porsche 914 Sweden ![]() ![]() Group: Members Posts: 369 Joined: 20-June 09 From: Sweden - Skivarp Member No.: 10,488 Region Association: Scandinavia |
I need a set if you can send to Sweden.
| Robarabian |
Apr 2 2026, 07:39 PM
914 A Roo ![]() ![]() ![]() Group: Members Posts: 743 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California
A bracket for sure. 1, maybe 2.
Ahh, what the hell, I need a rod with ball bearing too.. |
| mb911 |
Apr 3 2026, 04:26 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,794 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
I would be interested
| GTS |
Apr 4 2026, 07:04 AM
Member ![]() ![]() Group: Members Posts: 64 Joined: 7-October 04 From: South Austin,TX Member No.: 2,903 Region Association: None |
please a set to Texas,regards Stefan
| Root_Werks |
Apr 9 2026, 09:43 AM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,035 Joined: 25-May 04 From: About 15NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
I'd be in for a complete set.
Lo-Fi Version | Time is now: 29th July 2026 - 09:59 AM |
