| porschetub |
Mar 26 2026, 10:19 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,057 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Not really well titled but will proceed with more info ;
Engine hasn't been started for about 1yr due to an unrelated issue that I have only just found out about , so over that period I would expect the sump is holding a fair chunk of the oil tank capacity? ,for that reason the change of these exhaust valve covers will require a sump drain due to flood back from the stock tank ?. Old mag covers are buggered really even after being resurfacing twice,,they have gone soft I had these on and twice and got minimal leakage because the engine had been recently run . I have the covers , VR gaskets and mounting hardware ,thoughts from others would be very helpful ,cheers. |
| Luke M |
Mar 27 2026, 04:42 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,495 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States
Not really well titled but will proceed with more info ; Engine hasn't been started for about 1yr due to an unrelated issue that I have only just found out about , so over that period I would expect the sump is holding a fair chunk of the oil tank capacity? ,for that reason the change of these exhaust valve covers will require a sump drain due to flood back from the stock tank ?. Old mag covers are buggered really even after being resurfacing twice,,they have gone soft I had these on and twice and got minimal leakage because the engine had been recently run . I have the covers , VR gaskets and mounting hardware ,thoughts from others would be very helpful ,cheers. I would just drain the entire engine and tank oil. R&R the valve covers/gaskets and refill with new oil and filter. If you're using the turbo lower valve cover they'll need some of the fins milled down. There's a couple of ways to get this done. One would be to have a machine shop shave the fins down a bit or just remove enough of the fins to clear the suspension ear. There's a few threads here that cover this. |
| mlindner |
Mar 27 2026, 05:31 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,747 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest
You can remove plugs and turn engine over a couple 15 sec. and all oil will be back in the tank....but why, as Luke said just drain oil....Its shot.
| porschetub |
Mar 28 2026, 04:16 PM
You can remove plugs and turn engine over a couple 15 sec. and all oil will be back in the tank....but why, as Luke said just drain oil....Its shot. Thanks for the replies ,have drivers side cover already clearanced ,most likely go with second reply as my oil and filter have only done 150kms . I noticed the Dempsey 911 book states 6ft/lbs then says add further tourque if leaking !! I have thought the gaskets would be compromised by then ? anyone found this with the stronger 930 covers ? ,cheers. |
Lo-Fi Version | Time is now: 29th March 2026 - 04:08 PM |
