> Wiring Woes - Shorted Out Mystery Wires.
LefthandRev
post Apr 3 2026, 04:48 PM
I got into my car a couple days ago, turned the key, and the compartment started to smoke. Looked to my right and a couple of wires were melting behind the passenger seat. They had shorted and I grabbed and pulled to stop any potential fire (after shutting off the ignition).
Fast forward a couple days when I'm diagnosing things. I pull the passenger side seat out. Found the wires. Started tracing them, looking to see if there was something in the engine compartment, etc., found the probable cause for my woes - the coil was just laying flat on the engine shroud under the passenger side carb. One of the mounting screws had worked itself out and the whole thing was just sitting on the engine, so I'm sure it shorted whatever these wires are.
I'll dig into diagrams soon, but hopefully someone can save me a little time if they recognize them.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-25787-1775256488.1.png)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-25787-1775256489.2.png)
bkrantz
post Apr 3 2026, 07:49 PM
Part of the evil seat belt starter interlock system?
dtmehall
post Apr 3 2026, 07:59 PM
if the picture is accurate (IMG:style_emoticons/default/agree.gif)
removed it decades ago from mine
JeffBowlsby
post Apr 3 2026, 09:11 PM
If those two big fat yella wires are not connected together yet, it’s advisable to do that to avoid lotsa heartburn.
https://bowlsby.net/914/Classic/zTN_SeatbeltRelayBypass.jpg
ejm
post Apr 4 2026, 05:32 AM
I can see the light at the end of the tunnel
Looks like the power wire for the interior light.
Flyinlow
post Apr 4 2026, 08:59 AM
Flyinlow
QUOTE(JeffBowlsby @ Apr 3 2026, 08:11 PM) *
Question…when those yellow wires are connected does that render the rest of them inoperable? (IMG:style_emoticons/default/blink.gif)
JeffBowlsby
post Apr 4 2026, 03:21 PM
It takes circumvents the seatbelt interlock relay, which if defective, prevents your car from starting.
porschetub
post Apr 4 2026, 03:22 PM
QUOTE(Flyinlow @ Apr 5 2026, 03:59 AM) *
I believe so , my roller came less the relays , I cut the fat yellow cables going into the relay block and used a large Duraseal connector ,simple crimp and heat to provide a sealed joint .
Cheers.
porschetub
post Apr 4 2026, 03:30 PM
Cheers.
- Lo-Fi Version Time is now: 5th April 2026 - 11:26 AM
