| robkammer |
Apr 8 2026, 07:24 AM
Robbo ![]() ![]() Group: Members Posts: 266 Joined: 7-January 21 From: Vermilion Ohio Member No.: 25,049 Region Association: NineFourteenerVille |
Teeners, while I had the engine out I had hoped to replace is the speedometer boots at the tranny and firewall. Now I realize that may not be possible without pulling the cable out of the tunnel and dash. Has anyone successfully stretched the boots over the rear fitting?
Robbo |
| rgalla9146 |
Apr 8 2026, 08:11 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,954 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
Teeners, while I had the engine out I had hoped to replace is the speedometer boots at the tranny and firewall. Now I realize that may not be possible without pulling the cable out of the tunnel and dash. Has anyone successfully stretched the boots over the rear fitting? Robbo I don't think it's possible even if you did remove the cable. The 'nut' at the speedometer end is large and the hole in tthe boot is very small. |
Lo-Fi Version | Time is now: 9th April 2026 - 12:51 AM |
