> 5-lug conversion, What exactly is needed for 5-lug conversion and where do I buy?
rbmorrisiii
post Apr 9 2026, 08:59 AM
I want to do a 5 lug conversion, and went and talked to Bill at Eason Auto Works in Oakland. He said he could do it, and the best way to go about it was sourcing front struts from a 74-81 911sc - complete with brakes. He also said it was going to be tough to find.
I've looked a little online, and it seems a little bleak, but also I'm not exactly sure what I'm looking for. Is there a photo or list or something that shows me absolutely everything I will need? Minimally? Maximally?
Also, what's the best way to go about finding these things? What would you do?
Any info would be much appreciated.
post Apr 9 2026, 09:06 AM
914-6 GT in waiting
Read this thread first - www.914world.com/bbs2/index.php?showtopic=105728
914werke
post Apr 9 2026, 09:08 AM
PM me I may have everything you re looking for
914Wes
post Apr 9 2026, 09:09 AM
First step, determine which front struts you really want. This is based off what brakes you are going to run. You have options of 3.0" or 3.5" caliper spacing as well as Boge(black), Koni(red/orange), or Bilstein (green) front struts. Bilstein struts are the best if you are going to drop spindle (lower) the front end. Bilstein struts can only use Bilstein inserts. Boge struts are the best in terms of price and insert options since you can get Boge, Koni, or Bilstein inserts for them. Koni struts are more rare as they were special order options, can only take koni inserts, but are adjustable. If you go with 3.5" spacing you can do with A or S calipers. A perfect match for those in the rear would be Eric Sheas repop 914-6 calipers. If you do not want to upgrade your calipers you can use a 3.0" strut with solid rotor front rotor, or ad spacers and get a vented in the front. You can also go the cheap route and drill the rotors for 5 lug and install studs but that only gets you the benefit of 5 lug wheels.
sixnotfour
post Apr 9 2026, 09:22 AM
QUOTE(914Wes @ Apr 9 2026, 09:09 AM) *
yup REDRUM
Jack Standz
post Apr 9 2026, 10:04 AM
Here:
https://pmbperformance.com/pages/porsche-91...onversion-guide
brant
post Apr 9 2026, 12:12 PM
3 inch struts and brakes are easier to find and completely adequate
What pmb recommends and cheaper than 3.5
You still get the vented brakes that came on the -6
brant
post Apr 9 2026, 12:14 PM
You’ll likely need new rotors, brake rebuild kits, and ball joints you can source from pmb
sixaddict
post Apr 9 2026, 04:56 PM
Lots of good and knowledgeable recommendations……..you didn’t say it but is car 4 or 6.
If a 4 you only need 3” as stated…..even a street 6. Only thing I would disagree with is the shops caveat about being hard to find……May not be any current listings but fairly easy to locate. Just my 2 cents.
post Apr 9 2026, 05:41 PM
914-6 GT in waiting
QUOTE(sixaddict @ Apr 9 2026, 06:56 PM) *
Over the years, I've sold dozens of 911 front suspension to 914 guys. Hard to find, no. Has it gotten pricier to do the swap, yes. But it opens you up to many more wheel options and bigger calipers and rotors.
Remember, you will need 911 hubs, hard brake lines, soft brake lines, new pads, hardware, possibly strut inserts, new ball joints, trim down the 911t rear rotor a couple mm, new bearings front and rear and any used calipers you buy will probably need to be redone or restored. Usually turbo tie rods are done at this time.
Count on $2-3K + (not including wheels and tires) to do it right. More if you want aluminum calipers like Alfa's or 911S.
PMB also sells a less expensive kit that just swaps out the hubs but keeps your struts and calipers. Not a bad move for a narrow body car.
- Lo-Fi Version Time is now: 10th April 2026 - 01:21 AM
