> Advance 123 distributor and GoWesty throttle body, Questions about the install...
TRP
post Apr 21 2026, 10:50 AM
Hey Gang!
I am about to stuff the 2056 back into my car and I wanted to double check a few things before I dive head long into this thing.
My A123 has a vacuum port on the side of the distributor body. The GoWesty throttle body also has the vacuum port. I assume I connect the TB to the A123 ports and I'm good to go. I ask because there are lots of comments about 'if the port is before / after the throttle blade. The port appears to be in the same approximate location as the stock 1.8 TB, so I think this is correct.
Second question, with the 2056 and the Raby "FI compatible" cam, the rest is stock L-Jet FI (I moved the TPS over to the GWTB) -- which of the pre-programmed advance curves should I be selecting in the A123?
Thank you!
Ted
2 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
1 Members: TonyA
- Lo-Fi Version Time is now: 21st April 2026 - 05:57 PM
