> FJ67 injectors, New seals; clamp finishes seating. OK or leak risk?
Stef914
post Apr 21 2026, 11:24 PM
human
Hi all,
Quick sanity check on injector install.
I just installed a set of Standard Motor Products FJ67 injectors on my 2.0 D-Jet with brand new seals at the intake runners.
What surprised me:
* No “click” when inserting them
* Only the tip went in
* Final seating seemed to happen when tightening the retaining clamp
They’re now sitting straight and look properly aligned, but I’m not fully confident they seated by hand before the clamp pulled them in.
I can also still see a bit of the rubber seal sticking out at the base (see picture).
I’ve only done one side so far, still need to do the passenger side, so I haven’t been able to run the engine and test for leaks yet.
Is this normal with new seals on these cars?
Should they fully seat by hand before the clamp goes on?
Any risk of vacuum leaks if the clamp did part of the seating?
For context, seals were installed dry.
Thanks y’all
mgphoto
post Apr 22 2026, 12:17 PM
"If there is a mistake it will find me"
Looks correct, the rubber is an insulator so the gap is fine. The larger o-ring when placed correctly it puts the pressure on the port to prevent an air leak.
In this case only the tip goes in.
DRPHIL914
post Apr 22 2026, 02:07 PM
Dr. Phil
QUOTE(Stef914 @ Apr 22 2026, 01:24 AM) *
Hi all,
What surprised me:
Thanks y’all
i just installed mine as well, and noticed that the nose is shorter than the OEM ones, but tip width is the same and with new seals i found i have a good tight seal wwhen the retainer is tightened down.
Stef914
post Apr 22 2026, 03:36 PM
human
Thanks guys! There’s always that percentage of “I absolutely don’t know what I’m doing” in the back of my mind (IMG:style_emoticons/default/aktion035.gif)
sithot
post Oct 12 2026, 01:22 PM
Bill Johnson (Mr. Injector) approved. I'm running them. Too bad they used to be about $70. As Inspector Clouseau said: "Not Anymore".
- Lo-Fi Version Time is now: 24th October 2026 - 01:59 PM
