> Original 6 carb fuel line configuration
sixaddict
post Apr 22 2026, 04:19 PM
Anyone have a photo of correct fuel line configuration between carburetors (and source).
Thanks
DennisV
post Apr 22 2026, 05:41 PM
QUOTE(sixaddict @ Apr 22 2026, 03:19 PM) *
Thanks
Did you peruse BaT? There are some very original cars with engine photos with carbs exposed on there.
fixer34
post Apr 22 2026, 05:52 PM
QUOTE(sixaddict @ Apr 22 2026, 05:19 PM) *
Thanks
I'm charging the battery on mine right now, I can take a couple pictures.
If you want concours originality though, be aware I pulled the cold start valve and fuel line T a long time ago.
930cabman
post Apr 22 2026, 05:57 PM
QUOTE(fixer34 @ Apr 22 2026, 05:52 PM) *
Thanks
Cold start valve? I was unaware our Weber equipped /6 engines had this feature
fixer34
post Apr 22 2026, 06:16 PM
QUOTE(fixer34 @ Apr 22 2026, 06:52 PM) *
Thanks
Here you go. Fuel pump underneath, to the fuel filter and fuel rail to carbs.Attached Image Attached ImageAttached Image
fixer34
post Apr 22 2026, 06:24 PM
QUOTE(930cabman @ Apr 22 2026, 06:57 PM) *
Thanks
Yep, at least the very early models. 'T' into the fuel line after the filter, went to a valve that was temperature sensitive I believe and connected to the starter solenoid. That provided raw fuel to rails in the air cleaner housing that sprayed right down the carb stacks. What could possibly go wrong??
930cabman
post Apr 22 2026, 06:29 PM
Mr Fixer came through, great shots and
(IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/piratenanner.gif)
"what could go wrong" LMAO
Recalling, I have seen this before
sixaddict
post Apr 22 2026, 07:53 PM
Fixer…..provided pics I was looking for.
This was from a set that I sold but I believe it was too perfect.
3 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
2 Members: 930cabman, scrz914
- Lo-Fi Version Time is now: 22nd April 2026 - 10:40 PM
