| Cvrguy |
Apr 22 2026, 06:50 PM
Newbie ![]() Group: Members Posts: 22 Joined: 18-September 25 From: Los Angeles Member No.: 28,995 Region Association: None |
Any tricks to adjusting the front ride height on a 914?
| L-Jet914 |
Apr 22 2026, 06:54 PM
Member ![]() ![]() Group: Members Posts: 391 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
Front ride height is adjusted by the torsion bar adjusters on the back of the lower control arms. Once that height is changed you will need to have your vehicle's alignment readjusted.
| bkrantz |
Apr 22 2026, 08:09 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,667 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
You can follow the factory strategy, and set the height of the inner arm pivots (see the illustration from the factory manual).
You can do it by eye, high or low, and constrained by interference of wheels and tires with fenders or other fixed parts. You can do it by alignment specs, especially camber and caster, with stock struts or modified sruts. Or ??? |
| dtmehall |
Apr 22 2026, 08:39 PM
Member ![]() ![]() Group: Members Posts: 275 Joined: 21-December 23 From: Michigan Member No.: 27,808 Region Association: Upper MidWest |
You can follow the factory strategy, and set the height of the inner arm pivots (see the illustration from the factory manual). You can do it by eye, high or low, and constrained by interference of wheels and tires with fenders or other fixed parts. You can do it by alignment specs, especially camber and caster, with stock struts or modified sruts. Or ??? I believe that can find many pictures that have been posted of cars that you can refer to |
Lo-Fi Version | Time is now: 22nd April 2026 - 10:40 PM |
