> Tips and tricks on swapping this from one trans to another?
Tdskip
post Apr 24 2026, 09:25 AM
Hi - happy Friday all.
I pulled the professionally rebuild but incorrectly assembled (ugh!) gearbox to install one that Dr Evil rebuilt (yah!). I need to swap the whole assembly as a unit (#10 and all the attached parts) over which would be the first time I'm doing that so it seemed prudent to ask for some coaching to make sure I do it properly.
Best to do prior to installing the Dr Evil rebuilt box or can it be done as easily once that is installed on the car? Any tips on making sure I get the alignment correct?
Thanks!
Shivers
post Apr 24 2026, 09:57 AM
QUOTE(Tdskip @ Apr 24 2026, 08:25 AM) *
Thanks!
I'd replace #20, out of the car is good. Shift it into neutral. There are two nuts that hold it in. Remove those and I just wiggled mine out. It will all stay together except maybe #20.
Tdskip
post Apr 24 2026, 10:12 AM
QUOTE(Shivers @ Apr 24 2026, 10:57 AM) *
Thanks for the reply, sounds pretty straightforward.
TRP
post Apr 24 2026, 10:29 AM
Oh man, this is very timely! I have to swap that same part (parts?) out from one trans to anther today. One is modified for the CF Racing shift linkage and the other isn't. I don't want to retain the Tangerine linkage and not have to rework two of them.
Thank you!
Ted
TRP
post Apr 24 2026, 12:43 PM
QUOTE(TRP @ Apr 24 2026, 09:29 AM) *
Thank you!
Ted
All done! Man... why does gear oil smell so horrible? (IMG:style_emoticons/default/barf.gif) Smells like 5 years of body odor and regret.
Montreal914
post Apr 24 2026, 02:39 PM
Did your “professional “ rebuilder check/replaced bushing #11 and replaced seal #12?
Before installing the console, you may want to check…
Tdskip
post Apr 24 2026, 03:40 PM
QUOTE(Montreal914 @ Apr 24 2026, 03:39 PM) *
Will check for sure, thanks for pointing that out.
- Lo-Fi Version Time is now: 25th April 2026 - 01:47 AM
