> 914World Classifieds Rules
> WTB: Vent Hoses for Fuel Vapor @ Canister and @ Engine Compartment, NOT the plastic ones @ rocker panels
Literati914
post Apr 29 2026, 07:40 PM
I've got a '73 that I'm wanting to replace the fuel venting system on.. though I think all early cars had the same set up. They are braided and probably close to 1/2" or so ID. (I could probably use the thin ones too, to and from the expansion tank)
I need the ones up front that connect to the charcoal canister as well as the ones that connect to the air cleaner box and the fan housing. This is a 1.7L if that matters.
If someone's parting out an early car and have these, let me know. Or if someone's got a good source to recommend, that would be great too.
914werke
post Apr 30 2026, 11:42 AM
So you Want the OE plastic lines that run from F to R of the car along the drivers rocker or you want the short ones (same material) that go from wheel well to tank mounted charcoal can?
friethmiller
post Apr 30 2026, 12:57 PM
QUOTE(Literati914 @ Apr 29 2026, 08:40 PM) *
I had an early '74 that I parted out with that same setup. Let me see what I have.
Literati914
post Apr 30 2026, 02:55 PM
QUOTE(914werke @ Apr 30 2026, 12:42 PM) *
No - my title says NOT those plastic ones at the rocker covers. It also says the ones I'm looking for are braided. They are original German cloth braid.
QUOTE(friethmiller @ Apr 30 2026, 01:57 PM) *
Great LMK, I think they may have moved the canister to the back in late '74 - so your early '74 may have what I need.
- Lo-Fi Version Time is now: 30th April 2026 - 08:52 PM
