| jacktarnold |
May 3 2026, 01:20 PM
Newbie ![]() Group: Members Posts: 6 Joined: 23-October 20 From: Alabama Member No.: 24,799 Region Association: South East States |
Hi all,
Looking for some guidance before I go too far down the rabbit hole. I’ve got a 1973 914 2.0 that I’m bringing back after about 10 years off the road. I’ve gone through the fuel system and brakes, got it running, and took it out for a short test drive. Issue: I could never find 4th or 5th gear. I started working through the shift linkage by checking bushings and alignment and found that the rear shift rod retaining screw appears to have been previously repaired with a Helicoil. Unfortunately, that insert is now backing out, so the connection isn’t solid. Before I start tearing deeper into it, I’m trying to figure out the best path forward: * Is it worth redoing the Helicoil, or should I go another route? * Any preferred repair methods for this specific location that hold up long-term? Appreciate any advice or lessons learned |
| Jack Standz |
May 3 2026, 02:41 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 784 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
New couplers are pretty expensive, so you could put a "wanted to buy" add here for a used one?
Not sure if it's worth trying to weld it up and cut new threads, unless you have the equipment and skill. Good luck. (IMG:style_emoticons/default/biggrin.gif) |
| Shivers |
May 3 2026, 02:56 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,371 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Hi all, Looking for some guidance before I go too far down the rabbit hole. I’ve got a 1973 914 2.0 that I’m bringing back after about 10 years off the road. I’ve gone through the fuel system and brakes, got it running, and took it out for a short test drive. Issue: I could never find 4th or 5th gear. I started working through the shift linkage by checking bushings and alignment and found that the rear shift rod retaining screw appears to have been previously repaired with a Helicoil. Unfortunately, that insert is now backing out, so the connection isn’t solid. Before I start tearing deeper into it, I’m trying to figure out the best path forward: * Is it worth redoing the Helicoil, or should I go another route? * Any preferred repair methods for this specific location that hold up long-term? Appreciate any advice or lessons learned a time sert would be the fix in my opinion. It really is better than the spring. https://www.timesert.com/ |
| FlacaProductions |
May 3 2026, 03:00 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,194 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
Put a WTB up - I'm sure someone has one - or someone here on this thread will speak up.
| 930cabman |
May 3 2026, 03:03 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,647 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
I would consider this: https://tangerineracing.com/shop/ols/produc...-alignment-tool anything from Tangerine is top shelf Great bring another from a slumber |
| JamesM |
May 3 2026, 03:38 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,199 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
(IMG:style_emoticons/default/welcome.png) I would consider this: https://tangerineracing.com/shop/ols/produc...-alignment-tool anything from Tangerine is top shelf Great bring another from a slumber Agree, but given the looks of that shift coupler, I would put my money here instead. https://tangerineracing.com/shop/ols/produc...ift-linkage-kit Its also worth noting we are starting to see more and more of the hole for the cone screw in the forward shift rod getting wallered out as well. ANY play in the joint of the two rods is going to result in not enough travel at the shift head to hit all the gears. |
| jacktarnold |
May 3 2026, 06:11 PM
(IMG:style_emoticons/default/welcome.png) I would consider this: https://tangerineracing.com/shop/ols/produc...-alignment-tool anything from Tangerine is top shelf Great bring another from a slumber Agree, but given the looks of that shift coupler, I would put my money here instead. https://tangerineracing.com/shop/ols/produc...ift-linkage-kit Its also worth noting we are starting to see more and more of the hole for the cone screw in the forward shift rod getting wallered out as well. ANY play in the joint of the two rods is going to result in not enough travel at the shift head to hit all the gears. This definitely looks like the most complete option; however, I'm hesitant to do this as I don't really want to cut and drill into the transmission to complete it. |
| bkrantz |
May 3 2026, 06:58 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,681 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
Hi all, Looking for some guidance before I go too far down the rabbit hole. I’ve got a 1973 914 2.0 that I’m bringing back after about 10 years off the road. I’ve gone through the fuel system and brakes, got it running, and took it out for a short test drive. Issue: I could never find 4th or 5th gear. I started working through the shift linkage by checking bushings and alignment and found that the rear shift rod retaining screw appears to have been previously repaired with a Helicoil. Unfortunately, that insert is now backing out, so the connection isn’t solid. Before I start tearing deeper into it, I’m trying to figure out the best path forward: * Is it worth redoing the Helicoil, or should I go another route? * Any preferred repair methods for this specific location that hold up long-term? Appreciate any advice or lessons learned a time sert would be the fix in my opinion. It really is better than the spring. https://www.timesert.com/ Agreed time-sert are still a patch, but at least are actually machined and threaded. Helicoils are like duct tape. I bet a proper time-sert with high strength thread lockers would be a permanent fix. |
Lo-Fi Version | Time is now: 3rd May 2026 - 10:41 PM |
