| mlw914 |
May 8 2026, 05:37 PM
Newbie ![]() Group: Members Posts: 5 Joined: 6-November 24 From: Los Gatos, CA Member No.: 28,449 Region Association: Northern California |
Hello 914W,
I am going to update the suspension in my '73 914 6 conversion. It's got a 3.0l in it, dual PMO's, Cayman 4 piston calipers and 911 discs, 321 ignition, Patrick Motorsports conversion kit and front oil cooler kit, running 16" Ultralights to accommodate the brake rotors. Sway bars F & R as well. I am doing some suspension upgrades and wanted suggestions on what suspension components you all would suggest. I am leaning towards Bilstein units but not sure. I also wanted to know from those with more experience and knowledge regarding the parking brake setup. Obviously with the Cayman calipers I can't use the old system and its gone. What have you done or seen done to allow for an e brake? Don't get me wrong, my $7 Harbor Freight wheel chock is working great, just not an ideal setup. I have heard of compression lock systems and modern electric options but don't have any specifics so please, bring it on! Much thanks! Mike in NorCal |
| Ninja |
May 8 2026, 06:03 PM
Member ![]() ![]() Group: Members Posts: 209 Joined: 25-September 25 From: Granbury Texas Member No.: 29,004 Region Association: Southwest Region |
Ground Control rear springs/adjustable perches.
I like the Koni parts due to adjustability and warranty. Many prefer Billies... Mod rear trailing arms for early 911 parking brake assemblies. Tangerine Racing makes cable adaptors to allow 914 stock E-brake cables to work. I'm planning on strengthening the suspension points, adjustable tension rods to inner rear trailing arm mount. Adjustable/triangulated outer rear suspension mount plate (improves the strength and makes rear alignment easier). What front strut housings you are using may dictate which insert you can use. Your car sounds nice! Look at Tangerine Racing, Elephant Racing, PMB websites if you haven't yet. Welcome to the forum! |
| wndsrfr |
May 8 2026, 07:52 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,462 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region
Maybe try this.....Wilwood Spot Brake....
you'll have to engineer mounting and cable routing....YMMV https://www.wilwood.com/Calipers/CaliperProd?itemno=120-1360 |
| Steve |
May 8 2026, 08:28 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,042 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
Always check the how to forum
http://www.914world.com/bbs2/index.php?showtopic=4909 I used the above info and early 911 shoe emergency brake. Make sure you weld an angle iron to the trailing arm to keep the shoes from braking loose during an emergency stop. There’s a reason why the factory did it with 911’s. |
| mlw914 |
May 8 2026, 08:58 PM
Ground Control rear springs/adjustable perches. I like the Koni parts due to adjustability and warranty. Many prefer Billies... Mod rear trailing arms for early 911 parking brake assemblies. Tangerine Racing makes cable adaptors to allow 914 stock E-brake cables to work. I'm planning on strengthening the suspension points, adjustable tension rods to inner rear trailing arm mount. Adjustable/triangulated outer rear suspension mount plate (improves the strength and makes rear alignment easier). What front strut housings you are using may dictate which insert you can use. Your car sounds nice! Look at Tangerine Racing, Elephant Racing, PMB websites if you haven't yet. Welcome to the forum! Thanks for the info and welcom! Much appreciated, Mike |
| mlw914 |
May 8 2026, 08:59 PM
Maybe try this.....Wilwood Spot Brake.... you'll have to engineer mounting and cable routing....YMMV https://www.wilwood.com/Calipers/CaliperProd?itemno=120-1360 Much thanks! Appreciate the help. Mike |
| porschetub |
May 9 2026, 12:07 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,106 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Always check the how to forum http://www.914world.com/bbs2/index.php?showtopic=4909 I used the above info and early 911 shoe emergency brake. Make sure you weld an angle iron to the trailing arm to keep the shoes from braking loose during an emergency stop. There’s a reason why the factory did it with 911’s. (IMG:style_emoticons/default/agree.gif) not sure about fitting the 40mm spacer to the backing plate as per the link you supplied ,its real not heavy enough IMO to support and emergency handbrake stop if needed . Trailing arm mounting is best and thats how mine is done now ,cheers. |
| mlindner |
May 9 2026, 05:34 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,773 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest
| mepstein |
May 9 2026, 06:16 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,695 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Maybe try this.....Wilwood Spot Brake.... you'll have to engineer mounting and cable routing....YMMV https://www.wilwood.com/Calipers/CaliperProd?itemno=120-1360 Wilwood has a mounting plate for their spot brakes. They have a whole kit for their rear brakes with ebrake. It’s $1k for the rear calipers and another $1k to add the ebrake. |
| sixnotfour |
May 9 2026, 07:02 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,245 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
| Montreal914 |
May 9 2026, 08:55 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,103 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California
In the video, not sure I understand his drilled rear rotors (4 to 5 lugs) as these are vented disks... (IMG:style_emoticons/default/confused24.gif)
| mepstein |
May 9 2026, 10:36 AM
In the video, not sure I understand his drilled rear rotors (4 to 5 lugs) as these are vented disks... (IMG:style_emoticons/default/confused24.gif) I saw a couple of his videos as week ago. I only half paid attention since some of what he was saying and doing didn’t make much sense to me. Just because it’s on YouTube doesn’t make it right. |
| sixnotfour |
May 9 2026, 11:56 AM
ya its not the best vocal thought proccess,, But.. He had the 4 lug set up drilled to 5 lug ......simple .. the rest is show...at least he has done it ....they dont sell a 5 lug kit for 914s.. the 911 kits ive seen are nicely packaged and go instructions...bolt on..
| porschetub |
May 9 2026, 05:31 PM
That video is corrupted ,don't try to play it ,took me 30mins to get my laptop working again and to say I was pissed off was an understatement ...it should be removed from this thread . I had to power on and off till HP surestart kicked it ..rant over. |
| sixnotfour |
May 9 2026, 08:52 PM
Anyone else ??
QUOTE That video is corrupted ,don't try to play it ,took me 30mins to get my laptop working again and to say I was pissed off was an understatement ...it should be removed from this thread . I had to power on and off till HP surestart kicked it ..rant over. |
| Superhawk996 |
May 10 2026, 05:23 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,840 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Anyone else ?? QUOTE That video is corrupted ,don't try to play it ,took me 30mins to get my laptop working again and to say I was pissed off was an understatement ...it should be removed from this thread . I had to power on and off till HP surestart kicked it ..rant over. Video works fine. Porschetub is in New Zealand . . . Maybe all the 1’s and 0’s flip flopped when crossing into the southern hemisphere (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/laugh.gif) |
| Superhawk996 |
In the video, not sure I understand his drilled rear rotors (4 to 5 lugs) as these are vented disks... (IMG:style_emoticons/default/confused24.gif) I saw a couple of his videos as week ago. I only half paid attention since some of what he was saying and doing didn’t make much sense to me. Just because it’s on YouTube doesn’t make it right. (IMG:style_emoticons/default/agree.gif) |
| sixnotfour |
May 10 2026, 06:58 AM
This the one that shows the whole kit...turn volume of enjoy the kit visual... (IMG:style_emoticons/default/beerchug.gif)
https://www.youtube.com/watch?v=yVZT9-_3LfQ I was thinking about it ,but went with Boxster brakes and 911 handbrake.....center lever.... REDRUM |
| mepstein |
May 10 2026, 07:16 AM
This the one that shows the whole kit...turn volume of enjoy the kit visual... (IMG:style_emoticons/default/beerchug.gif) https://www.youtube.com/watch?v=yVZT9-_3LfQ I was thinking about it ,but went with Boxster brakes and 911 handbrake.....center lever.... REDRUM Looked at the video again. Wilwood makes 5 lug rear disks. He just bought the kit for 4 lug. I don't know if they are willing to make a 5 lug kit but I would have asked them before buying the 4 lug kit or just simply bought the parts separately. My dealings with Wilwood have been great and they seem to be willing to work with the customer. I just bought the front and rear calipers since I'm using the tangerine kit to add 911 rear e-brakes/center lever to the car. We've bought a couple 911 caliper kits from Wilwood. They work great. They are a bit more expensive than Boxster brakes but are new vs used/rebuilt. By the time you have Boxster calipers rebuilt and repainted and buy the adaptors and hardware, the price is similar and turn around is days vs weeks. |
| sixnotfour |
May 10 2026, 09:27 AM
I Agree,,,but some people have have Porsh brakes.. (IMG:style_emoticons/default/beer.gif)
Lo-Fi Version | Time is now: 17th May 2026 - 01:48 AM |
