| moneysmarts |
May 11 2026, 09:48 AM
Member ![]() ![]() Group: Members Posts: 175 Joined: 2-March 04 From: Central Massachusetts Member No.: 1,745 Region Association: None
What's going on here? I've had the same set up for 20 years (2.0 D-Jet with MSD 66AL)
Now at 4500 rpm the tack drops out, then bounces wildly. Also if I use the directional signals, the tack drops. Ill try to add a little video |
| moneysmarts |
May 11 2026, 09:49 AM
Hmmm
Video wont upsoad |
| IronHillRestorations |
May 11 2026, 10:01 AM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,938 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
Try changing the points
| moneysmarts |
May 11 2026, 10:08 AM
| moneysmarts |
May 13 2026, 02:41 PM
Well. I have a nice clean dizzy with new points and condenser, but my tach still drops to zero and bounces back up and down at high revs. Smooth and steady from 1000 to 4500, then, boom. falls right off as the car is still reving higher.
I also noticed that at any RPM, if i use my directionals, the tack also freaks out. Almost like some electrical gremlin. I think all my grounds are good. Maybe I have bad bulbs that are causing feedback?? open to any recomendations |
| Spoke |
May 13 2026, 03:41 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
| porschetub |
May 13 2026, 03:58 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,105 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Well. I have a nice clean dizzy with new points and condenser, but my tach still drops to zero and bounces back up and down at high revs. Smooth and steady from 1000 to 4500, then, boom. falls right off as the car is still reving higher. I also noticed that at any RPM, if i use my directionals, the tack also freaks out. Almost like some electrical gremlin. I think all my grounds are good. Maybe I have bad bulbs that are causing feedback?? open to any recomendations Is your tach to coil wire in good condition/ connection ?, it seems to me the tach may have a poor earth or worst of all the tach is failing which due to age (ask me how I know ) my 911 tach pretty much did what yours is doing before total failuure . Worth checking all the wiring and maybe try a secondary tach to body ground wire and see what you achieve ? ,good luck cheers. |
| moneysmarts |
May 13 2026, 04:38 PM
Thank you
Is there a wire that runs from the tach through the tunnel directly to the coil? |
| Freezin 914 |
May 13 2026, 06:08 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 933 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest
Voltage regulator??.
| dtmehall |
May 13 2026, 06:10 PM
Member ![]() ![]() Group: Members Posts: 284 Joined: 21-December 23 From: Michigan Member No.: 27,808 Region Association: Upper MidWest |
i believe that the answer to moneysmarts question is yes
| cgnj |
May 13 2026, 07:01 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 710 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None
Thank you Is there a wire that runs from the tach through the tunnel directly to the coil? Black with Violet tracer. I do have a few questions. If your car is idling and you turn on the turn signal, does the tach still drop out? Have you bypassed the MSD? Download this fileEasiest electical diagram |
| moneysmarts |
May 13 2026, 07:48 PM
Thank you Is there a wire that runs from the tach through the tunnel directly to the coil? Black with Violet tracer. I do have a few questions. If your car is idling and you turn on the turn signal, does the tach still drop out? Have you bypassed the MSD? Download this fileEasiest electical diagram I just went outside and tried to duplicate while the car is idling, but I could not. I have not tried to bypass the msd. While driving though, the tack does drop momentarily when I use the turn signals. The switch is definitely effecting the tack. And of course it doesn't change the rpms at all Just the tack reading. |
Lo-Fi Version | Time is now: 13th May 2026 - 11:20 PM |
