| L-Jet914 |
May 12 2026, 11:49 PM
Member ![]() ![]() Group: Members Posts: 395 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
Good evening fellow Teeners. I have a question regarding the thermostat cable. How does the thermostat cable thread into the thermostat? I was looking at replacement cables and it doesn't look like it has a threaded section to the cable. I started to disassemble the underside to replace my push rod tube seals and perform a valve adjustment. I know I need to replace my thermostat which I just found out today had failed after lord knows how long (still has the VW logo and part number). I tried to remove the thermostat cable from the old thermostat and it snapped off inside which I am not surprised due to the age of the vehicle. Thank you in advance. (IMG:style_emoticons/default/smile.gif)
| mepstein |
May 13 2026, 03:32 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,687 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
It’s just a bicycle derailleur cable. The clamp is on the flaps.
| Jack Standz |
May 13 2026, 12:29 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 788 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
The cable isn't threaded. It's connected to the thermostat with a hollow threaded piece as shown here:
https://resto9.nl/en/product/bevestigingsbu...el-porsche-914/ |
| L-Jet914 |
May 13 2026, 08:30 PM
Thank you everyone for your input. Well I learned the hard way haha. I will be purchasing a derailleur cable to replace it and cut to fit. My other question is what size grommet has everyone installed to replace the NLA grommet that keeps the cable from chaffing against the cooling tin? Do you install one that sits flush on the tin or on the bottom side of the tin underneath?
Lo-Fi Version | Time is now: 13th May 2026 - 11:21 PM |
