> Engine trouble, Dies at idle
trojanhorsepower
post May 17 2026, 08:14 AM
All,
I have been enjoying my car but have a recurring issue.
Starts great
Runs fine for maybe 20 min
Starts to once in a while act like it turned off for just a 1/2 sec then comes back on - causing the car to lurch and the shifter to jump
After about 30 or 40 min the car dies if stopped and allowed to idle. It just drops off spools down to nothing,
It restarts if you hold the gas peddle all the way down. Sometime when it restarts it is weak, then it goes fine.
As long as the car is in gear and moving it does not die.
It will continue to do this until I get home. If I am coordinated enough I can shift into neutral, work the brake with my left foot and keep the RPMs up a bit with my left and it seems fine (no stumbling or trying to die at higher RPMs) but if I come to a light, stop and let it idle it will just idle down to nothing.
Sometimes when I get home it will idle fine until I turn it off. Other times it just dies.
Seems to pull great all through the range
Always restarts
Any ideas where to start?
Thanks
Peter
Ishley
post May 17 2026, 08:56 AM
First off what year car. What modifications are in the car? Engine size, cam etc. Are you running original fuel injection or carbs? If carbs what type. What did you last do to the car? Have you maintained the fuel system. Fuel filter good? Fuel pressure good?
emerygt350
post May 17 2026, 11:27 AM
QUOTE(Ishley @ May 17 2026, 08:56 AM) *
And what distributor is in it.
trojanhorsepower
post May 17 2026, 01:31 PM
Hmmm yeah probably should have included all that..
1974, 4cyl 2056 factory fuel injection, rebuilt distributer (Bill Fowler, it looks great)
Other than being a 2056 it is stock.
Did the same thing with the original distributer, new cap wires rotor....
wonkipop
post May 17 2026, 02:41 PM
QUOTE(trojanhorsepower @ May 17 2026, 01:31 PM) *
L jet or D jet?
trojanhorsepower
post May 17 2026, 02:50 PM
D Jet
wonkipop
post May 17 2026, 03:44 PM
QUOTE(trojanhorsepower @ May 17 2026, 02:50 PM) *
D Jet
can't help with d jet.
but something it could be with either type is a collapsing fuel line.
a tight bend somewhere.
bit of a classic symptom where it runs fine for a while but after a period running the fuel line begins to collapse and strangle off the fuel supply. often will come back to life if you gas it but left to idle will just die. could be up under the fuel tank or if the pump is still at the back under the engine where the lines come into the pump. look for tight bends in the line which might look crinkled in where they are curved around a bend.
trojanhorsepower
post May 17 2026, 04:00 PM
Sounds probable. I was ever happy with the fuel lines.
Thanks I will check it out.
Ishley
post May 17 2026, 05:24 PM
Difficult to tell... but it sounds electrical to me. I'd check the voltages at the coil and fuel pump when you get the issue. Could be your distributor also. Maybe the vacuum advance is sticking or the vacuum retard is sticking?
emerygt350
post May 17 2026, 06:59 PM
Has it always done this?
trojanhorsepower
post May 18 2026, 02:45 PM
Post restoration, yes. To some degree. It is worse now, but the car doesn't have 100 miles on it since I got it drivable.
Olympic 914
post May 18 2026, 04:24 PM
I had a similar issue.
It was the CHT sensor, intermittent failure.
Took a lot to finally figure it out.
emerygt350
post May 18 2026, 05:06 PM
Yes, cht is what I suspect as well. Sounds like it is running rich. Do you have an afr gauge? Check the connections to the cht (down by the #3 plug). My connection to the loom there has been troublesome. No easy way to troubleshoot that in the car. Check the resistance cold and the check it hot. If you pull it you can do a good job comparing it to what it should be.
trojanhorsepower
post May 19 2026, 04:15 PM
OK is the theory behind the CHT sensor being bad that the sensor resistance stay too high? From what I have read, as the motor heats up the resistance goes down. So for the CHT to cause this problem when the engine is warm the resistance would need to stay high? Do I have this correct?
emerygt350
post May 19 2026, 04:30 PM
QUOTE(trojanhorsepower @ May 19 2026, 04:15 PM) *
Yes, but it doesn't have to be crazy high. I suspect a few hundred ohms higher than it should be. They didn't put the 73 only resistor in that line did they? You should get us the numbers off your ECU and mps as well.
And it may not be bad. If the connection isn't good it can accomplish the same thing...
trojanhorsepower
post May 19 2026, 05:13 PM
OK, I got some numbers off the ECU. Unfortunately some of the tag has been scratched off.
039 906 0xxx
0 280 000 044
I cant see any numbers on the MPS
Olympic 914
post May 19 2026, 05:28 PM
The ECU needs to see some resistance from the CHT. If it's too high it will just be too rich but still run. Although badly, as seems your be your case.
But if it's disconnected or a bad connection it won't run.
One way to test it would be to substitute a resistor in place of the CHT.
~ 100 ohms would mimic a hot condition. Maybe not ideal if the engine is not warm. So you would unplug the CHT and add the 100 ohm resistor between the wire leading to the CHT and a good ground point. If that solves the issue your CHT sensor is bad.
- Lo-Fi Version Time is now: 20th May 2026 - 04:22 AM
