| bajafreaks |
May 18 2026, 02:46 PM
Member ![]() ![]() Group: Members Posts: 137 Joined: 7-February 14 From: Gardnerville, Nevada Member No.: 16,969 Region Association: Northern California |
What are recommendations for removing water spots from door glass?
As part of my restoration I need to clean up all of my glass, and they are all severally water stained. Tried a little fine steel wool and it didn't do much. Thanks |
| IronHillRestorations |
May 18 2026, 03:50 PM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,943 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
Try polishing compound
| windforfun |
May 18 2026, 03:59 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,099 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None
Vinegar aka acetic acid.
| FlacaProductions |
May 18 2026, 04:06 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,206 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
https://a.co/d/07vgNFNs
Chemical Guys Heavy Duty Water Spot Remover Gel |
| worn |
May 18 2026, 08:00 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,597 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
I have used cerium oxide and a felt buff with good results. Check your progress frequently because you don’t want to alter the shape of the glass or produce ripples. |
| TRP |
May 18 2026, 08:08 PM
Member ![]() ![]() Group: Members Posts: 365 Joined: 2-September 23 From: Morgan Hill, CA Member No.: 27,559 Region Association: None
Will second the Chemical Guys product, works well. I use it on my cars and home.
| bkrantz |
May 18 2026, 08:19 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,702 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
What are recommendations for removing water spots from door glass? As part of my restoration I need to clean up all of my glass, and they are all severally water stained. Tried a little fine steel wool and it didn't do much. Thanks Depends on if the spots are something on top of the glass or etched into the glass. |
| scallyk9 |
May 19 2026, 03:13 PM
Member ![]() ![]() Group: Members Posts: 378 Joined: 16-October 16 From: Port Orchard, WA, USA Member No.: 20,499 Region Association: Pacific Northwest
What are recommendations for removing water spots from door glass? As part of my restoration I need to clean up all of my glass, and they are all severally water stained. Tried a little fine steel wool and it didn't do much. Thanks Depends on if the spots are something on top of the glass or etched into the glass. If etched in, I used Griot's Garage glass polish with their 6" abrasive pad (looks like a very fine wet/dry sandpaper disc) for glass on my G-9 D/A polisher. I was a bit anxious at first because of the mild abrasive but was amazed at the result and later used it for all the side windows while out of the car in my restoration. |
| worn |
May 19 2026, 06:12 PM
What are recommendations for removing water spots from door glass? As part of my restoration I need to clean up all of my glass, and they are all severally water stained. Tried a little fine steel wool and it didn't do much. Thanks Depends on if the spots are something on top of the glass or etched into the glass. If etched in, I used Griot's Garage glass polish with their 6" abrasive pad (looks like a very fine wet/dry sandpaper disc) for glass on my G-9 D/A polisher. I was a bit anxious at first because of the mild abrasive but was amazed at the result and later used it for all the side windows while out of the car in my restoration. Cerium oxide is a very very fine abrasive. Nowadays you can move from finer to finer diamond grits as well, eventually getting fine enough to look polished. |
| 930cabman |
May 19 2026, 06:13 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,667 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
What are recommendations for removing water spots from door glass? As part of my restoration I need to clean up all of my glass, and they are all severally water stained. Tried a little fine steel wool and it didn't do much. Thanks Depends on if the spots are something on top of the glass or etched into the glass. If etched in, I used Griot's Garage glass polish with their 6" abrasive pad (looks like a very fine wet/dry sandpaper disc) for glass on my G-9 D/A polisher. I was a bit anxious at first because of the mild abrasive but was amazed at the result and later used it for all the side windows while out of the car in my restoration. Does this leave swirls? We have used cerium oxide |
| Luke M |
May 19 2026, 06:42 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,516 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States
What are recommendations for removing water spots from door glass? As part of my restoration I need to clean up all of my glass, and they are all severally water stained. Tried a little fine steel wool and it didn't do much. Thanks Check out Ian's how to videos. He has a you tube channel. He goes through the process on how to clean the glass. |
Lo-Fi Version | Time is now: 20th May 2026 - 04:23 AM |
