> 914World Classifieds Rules
> WTB good rebuildable 2L case, Looking for a 2L case for a rebuild
North Coast Jim
post May 22 2026, 08:14 AM
I'm in need a rebuildable 2L case. Anything available out there ??
bdstone914
post May 22 2026, 09:45 AM
bdstone914
QUOTE(North Coast Jim @ May 22 2026, 07:14 AM) *
Are you set on a 2.0 case?
They usually need more works and line bore compared to a 1.7 case
Ninja
post May 22 2026, 09:50 AM
The cases are interchangeable.
Many folks prefer the earlier cases.
All the original cases are now over 50 years old and all need at a minimum to be properly checked out by a machinist competent with air-cooled VW engines.
This is rare now-a-days...
It's even better if they know the differences between a T1 and a T4.
cgnj
post May 22 2026, 10:42 AM
I have three cases at the moment on FB ATM. W, What I believe is a replacement GA and EA code. All standard main and thrust. The saddles look good. here is the link
My facebook ad
w code mtors have the biggest rib structure so least likely to need to be decked, but no windage tray. Best for more than 96mm bore.
Whin I was young I always wanted a GA case. For most purposes EA is the way to go.
fiacra
post May 22 2026, 01:47 PM
Person.Woman.Man.Camera.TV. = MCI
PM sent. Not exactly what you are looking for as it is a complete 2.0 engine, but it might be of interest.
Jack Standz
post May 22 2026, 03:20 PM
[quote name='cgnj' date='May 22 2026, 11:42 PM' post='3258263']
quote]
Some,"W" cases have the provision for a windage tray, if that's important to you.
The "W" cases are more likely to need less clean up on the deck surfaces than later cases, but still are likely to need some machining. Definitely stronger and with deeper ribbing and thicker deck surface and thicker case, especially in the "roof" area.
914Sixer
post May 22 2026, 04:17 PM
I have an UNSTAMPED 2.0 case. Head studs removed and packaged. Case can be decked Easy to ship.
- Lo-Fi Version Time is now: 23rd May 2026 - 05:09 AM
