> Rear caliper pad vent adjustment, what is the magic?
VaccaRabite
post May 23 2026, 01:13 PM
En Garde!
New rebuild calipers.
I have not yet bled the brakes.
Inner rear adjustment went as I remember it going. Inner pads set at .005. I found a couple different specs for the adjustment so I just went with .005.
Outer rear adjuster just spins. I can spin it as much as I want and the pad does not move closer to the rotor. This is for both rear calipers. So I suspect operator error.
It’s been 15 years and I don’t remember the magic words.
For late calipers do you not need to adjust the outer adjuster? Is it just the inner adjuster that needs to get set?
HELP!
Zach
Shivers
post May 23 2026, 01:54 PM
Both should be adjusted. Outer adjuster- Remove the cap and the 13mm lock nut. Turn the 4mm hex screw counter-clockwise to retract the outer piston.Inner adjuster- Remove the steel cover. Turn the 4mm hex screw clockwise to retract the inner piston.
0.008
@VaccaRabite
VaccaRabite
post May 23 2026, 02:04 PM
En Garde!
QUOTE(Shivers @ May 23 2026, 03:54 PM) *
@VaccaRabite
Retracting isn’t an issue. The outer pad (and piston) is fully retracted. New pads when in with zero effort or issues.
My issue is I can’t get the outer adjusters to now push the piston and pad back towards the rotor, on either side of the car.
As for adjustment - I have seen everything from .002 to .008 inches. I picked .005. I think I saw PMB said .004. I suspect all of them will work just fine.
I’m kinda wondering if I need to bleed the brakes and just stomp the pedal a few times to wake up the outer adjusters or if there is something else I missed.
I can wait till Tuesday and just call PMB, but if I can figure it out this weekend all the better. I really should just know this, but the information leaked out of my brain at some point.
Zach
cgnj
post May 23 2026, 02:29 PM
I had a similar problem. recall watching PMB rear caliper rebuild. I put the caliper on the bench, applied pressure by hand on the non compliant piston and was able to get the adjustor to engage.
Ishley
post May 23 2026, 04:03 PM
You might need an inner adjuster gear. PMB sales them.
Superhawk996
post May 24 2026, 05:36 AM
See post #24
www.914world.com/bbs2/index.php?showtopic=90625&st=0
Same thing applies to inner and outer piston adjustment mechanism
VaccaRabite
post May 25 2026, 07:43 PM
En Garde!
For completeness,
I fixed the issue today.
I did need to bleed the brakes and stomp the pedal a few times to build pressure in the caliper. This woke up the adjuster. My rear pads are now set to spec.
Why? No idea. But it works and that is the important part. I suspect the piston was pushed way in during the rebuild and needed to get pushed ut a touch for the adjuster to function.
Now I’m in for rounds of bleeding. After the first round the pedal is still pretty mushy. Back on the lift and hopefully will be able to get another couple rounds of bleeding in before I have to go to Texas for a couple weeks.
Zach
emerygt350
post May 26 2026, 04:45 AM
How are you bleeding them? I just put that 19mm MC on mine and did not bench bleed but I quickly built pressure. Just did my last round yesterday to chase the last bit of air. I have a very very expensive tool for bleeding brakes called "my 13 yr old son". I think we have done 4 rounds now over 4 weeks, but we had good pressure and brakes after the first round. On rear venting I bring them in til I feel an ever so slight drag, just the most slight drag for each pad.
2 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
1 Members: 930cabman
- Lo-Fi Version Time is now: 26th May 2026 - 05:38 AM
