> Help Me Identify This Noise, Clicking Noise From Left Front Wheel Area
Osnabruck914
post May 27 2026, 05:41 PM
Almost every time I hand push my '74 2.0L out of the garage, I hear this annoying clicking noise coming from the left front wheel area. The noise seems to disappear once the car is out of the garage and I never hear it while driving. The noise seems to only occur when the car is pulled backwards and never forwards. I do not hear it if I jack the car up and spin the wheel. I have pulled the wheel and see nothing out of the ordinary that might cause it. I am stumped.
In the attached video below, the sound is quite amplified by my iPhone. The actual sound is far more subtle, but it is there. The crunching at the end of the video is just me pulling the hand brake to stop the car.
Does this sound familiar to anyone?
https://www.youtube.com/watch?v=Y-O02BBH-sc
Thanks,
Osnabruck914
mgphoto
post May 27 2026, 06:18 PM
"If there is a mistake it will find me"
Something could be in the wheel hub. Could be a bearing issue, could be something stuck in the caliper. Take the wheel off and see what the issue is, for peace of mind and before it becomes a major issue.
L-Jet914
post May 27 2026, 06:40 PM
Something is either loose in the wheel hub assembly, or it might be the pads shifting (which is normal on all disc brake vehicles).
rjames
post May 27 2026, 06:53 PM
I'm made of metal
Have someone sit in the car and lightly depress the brake pedal. Does the noise go away?
Osnabruck914
post May 27 2026, 09:33 PM
All good suggestions. I will investigate further. Thank you all.
Ninja
post May 28 2026, 09:05 AM
I'd put that puppy up in the air and spin it around.
Noise gone?
Look at wheel bearings. They now have no load on them.
Still noisy?
Have someone apply brake lightly and see if that changes it.
You can also use a mechanic stethoscope to locate the noise. They are cheap and I use mine weekly.
https://www.oreillyauto.com/detail/c/perfor...ASABEgJm3PD_BwE
PanelBilly
post May 28 2026, 05:17 PM
Inside the strut you could have the top nut loose. I had that issue and there was a strange knocking sound occasionally. Easy to check.
- Lo-Fi Version Time is now: 29th May 2026 - 10:10 AM
